Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #256 (permalink)
Old 03-02-2008, 10:40 PM
2000lightning 2000lightning is offline
2000lightning is starting off with a positive reputation.
It works
Worked great on an 2000 X.
Thanks Thanks Thanks
  #257 (permalink)
Old 03-11-2008, 08:54 PM
John_1953's Avatar
John_1953 John_1953 is offline
John_1953 is starting off with a positive reputation.
Just did the rear drivers side door. It hasn't worked for years. Now it works like a charm! Great thread! Can't wait to do all the other doors
__________________
1953 F-100: 352 FE, 4 Speed Toploader, 9" Rear.
1993 Ford Explorer: (sons car). 4.0L, 4X4, 5-Speed
2001 Ford F150 SuperCrew XLT. 4X2, 5.4L, AT
1998 Mercedes C280
http://www.ColorfulCansPainting.com
  #258 (permalink)
Old 03-12-2008, 06:17 PM
jdhill95 jdhill95 is offline
jdhill95 is starting off with a positive reputation.
Power Door Locks don't work
I have a 2001 Ford Exlporer Sport. None of the PDL's work including the 3rd door. Someone said it might be a relay. Has anyone else had this problem and found a solution? I looked at the fuse for the locks and it was fine.fficeffice" />>>
  #259 (permalink)
Old 03-21-2008, 12:21 PM
RAAAMAD RAAAMAD is offline
RAAAMAD is starting off with a positive reputation.
Also Works on Windstar Door Lock Actuators
Any time I can keep money in my pocket, and not give it to Ford for design shortcomings, I am very pleased!
Thanks FTE!
  #260 (permalink)
Old 03-22-2008, 10:44 PM
stang67k stang67k is offline
stang67k is starting off with a positive reputation.
I found this site yesterday and most importantly this thread. Today I fixed my PDLs in my 99 F-150. After reading every post I went with the .01 copper fix and the locks now work flawlessly. I still can't believe I fixed both doors for ONE penny!!!! The job was easy due to the detailed instructions in this thread. All I can say is Awsome and thanks to everyone who posted this helpful information on this site.
Dale
  #261 (permalink)
Old 03-24-2008, 03:01 PM
Chappper Chappper is offline
Chappper is starting off with a positive reputation.
Canīt take the actuator out of the door!
Hi I own a F250 xlt (This is a Mexican truck, Iīm from Monterrey Mexico)...I have found this site very interesting and has helped me troubleshoot some issues in my truck.
The issue that Iīm having right now is the PDL actuator (all the same symptoms that you stated in this thread). I already tried to take out the PDL from the passenger side, but I canīt! I already took out the 3 torx screws, and also I took out the metal connection between the PDL and the Lock itself. But itīs still attached to the key metal connection I canīt reach that clip! Also I tried to take out the door handle, but also, it has an interior screw that for me itīs unreachable, so thatīs no option!
Any ideas how can I take out the actuator. I already read two times all the thread but I still can take out the PDL.
Best regards!
Chappper
  #262 (permalink)
Old 03-25-2008, 10:02 AM
brotherf350 brotherf350 is offline
brotherf350 is starting off with a positive reputation.
Door locks and door panel
Does anyone have a quick way to remove door panel to get at lock mechanism without damaging panel. Thanks
  #263 (permalink)
Old 03-25-2008, 01:05 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Yes,,, after you have removed all the attachment item holding the door panel slide it vertical to get the hooks off of the door frame. This will prevent damage to them and allow you to reuse the panel without damage.
  #264 (permalink)
Old 03-25-2008, 02:19 PM
Budman1962 Budman1962 is offline
Budman1962 is starting off with a positive reputation.
Its all on page 6 of the thread.
Budman
__________________
When the drive is through this Buds for you!
2000 F-250 V-10 SWB CC
  #265 (permalink)
Old 04-03-2008, 01:21 PM
lockdoc600's Avatar
lockdoc600 lockdoc600 is offline
lockdoc600 is starting off with a positive reputation.
After two years of frustration with my 2000 X I decided it was time to fix the door locks. I searched online to see if I could find some aftermarket OEM type actuators and found this thread instead!!! THANKS TO ALL OF YOU! I fixed my lock actuators last night and it only cost me .03!
I did have to go back and re-do the cases on two of them as I drilled off the rivets and found that that end needs to be secure! Re-melting plastic won't cut it on the ends! Also made up some tools for holding the brushes apart while re-installing the end cap of the motor over the armature and found out that they won't take too much effort to bend the little brass arms holding them! I had to reopen one of the three to fix the brush arms! But I got done and now my locks go up and down with the push of the button once each time!!
I am happy enough to on!
Thanks again for starting this thread!
  #266 (permalink)
Old 04-03-2008, 01:42 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Show your thanks by giving the original poster some reputation points, and anyone else involved that contributed along the way.
Click on the scales icon on the upper right side of their post.
It's the best way to show your appreciation. Thanks!
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #267 (permalink)
Old 04-03-2008, 01:58 PM
MarkMoore's Avatar
MarkMoore MarkMoore is offline
MarkMoore has a good reputation on FTE. MarkMoore has a good reputation on FTE. MarkMoore has a good reputation on FTE.
I plan on doing mine next week... wish me luck!
__________________
- The Urban Assault Vehicle -
2001 Excursion Limited, 4x4, V10, 3.73
RoadMaster Active Suspension
2001 Prowler 31G
Equal-i-zer WD Hitch
Prodigy Brake Controller
http://www.ford-trucks.com/user_gall...id=194723&.jpg
  #268 (permalink)
Old 04-03-2008, 04:28 PM
lockdoc600's Avatar
Done and done...thanks for the tip on where to find the rep points scales!
  #269 (permalink)
Old 04-05-2008, 09:36 PM
oct7brian oct7brian is offline
oct7brian is starting off with a positive reputation.
All I got to say is that this might have been the best cheap fix I have ever found. Its right up there with resoldering the chips in the over head display. The only difference I did was I put two heav duty wire ties holding the plug end of the case together. Good tight fit and works flawlessly.
  #270 (permalink)
Old 04-06-2008, 09:58 AM
I did all 4 of my doors and they worked great for about 6 months. Then one by one they failed again. I have redone them all trying pennys, foil and copper wire. they just won't work for more than two weeks. I Had to buy new actuators from ford. The good news is they are redesigned. They don't look like the ones that came in my 2000 f250. They seem to have a stronger motor. The stealership charged me $57.00 each. You don't realize what a great feature power door locks are till you don't have them.
Budman
__________________
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. FordŪ is a registered trademark of the Ford Motor Company.
