Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #226 (permalink)
Old 12-13-2007, 04:07 PM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart
2000 Ford F-350
SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of SpringerPop has much to be proud of
If you had read this entire thread before you tried the fix, you wouldn't be taking it apart again. It's covered in the text why your motor is now running backwards.
You didn't put the motor in upside-down, you assembled the end cap on the motor 180 degrees out of alignment. You now have to take the motor completely apart again.
Pop
__________________
-Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX.
Email SpringerPop
  #227 (permalink)
Old 12-22-2007, 09:14 PM
Antelope V-10 Antelope V-10 is offline
Antelope V-10 is starting off with a positive reputation.
Just wanted to give an expereince of mine today while working on the actuator. I couldn't get the 3 Torx screws out to remove the latch. I stripped the Torx heads out. My neighbor, a body shop guy, came over and said they have to use heat to get them out. Sure enough, some propane torch heat and they backed out. The bolts had Blue Loctite on them.
__________________
'03, V-10, Auto, XLT, CC, SWB, 4x4, 4.30's Truetrac, Doug Thorley Headers, Rancho 2.5" Leveling Kit, F-350 4" Blocks, Les Schwab RMX Shocks, Fabtech Adjustable Trac Bar, Avon SXT All Terain 285's, S&B Filter, Magnaflow Catback 15869, '08 Rear Diff Cover, 5Star 87 Perf. Tune
  #228 (permalink)
Old 01-02-2008, 06:00 AM
f350ford17 f350ford17 is offline
f350ford17 is starting off with a positive reputation.
how do i get to the case? do i have to pull the whole inside of the door off?
  #229 (permalink)
Old 01-02-2008, 07:34 AM
19stroker99 19stroker99 is offline
19stroker99 is starting off with a positive reputation.
read the beginning of this thread it had step by step directions
  #230 (permalink)
Old 01-02-2008, 12:39 PM
dubble-dee dubble-dee is offline
dubble-dee is starting off with a positive reputation.
I just finished the actuator fix on my 2000 f150, and both work perfect.
  #231 (permalink)
Old 01-02-2008, 12:52 PM
fiveohpatrol fiveohpatrol is offline
fiveohpatrol is starting off with a positive reputation.
just wanted to post up another "thanks" I had done my drivers door on my '00 X a few months ago, then my front passenger door started crapping out. This weekend I ended up doing that one and the rear doors all in less than 2 hours total. All are working like new now
thanks again
  #232 (permalink)
Old 01-03-2008, 01:01 PM
G BOBKA's Avatar
G BOBKA G BOBKA is offline
G BOBKA is starting off with a positive reputation.
Okay now. I think I have. It was really easy to take apart and do the fix. Should be able to take the top off and spin it relatively easy and very short time. Thanks for your help on the backwards control system.
__________________
2000 Ford F350 XLT 7.3 4x4 Amsoil Bi-Pass with Amsoil through-out . Chiped with piller gauges(EGT,boost and trans).4"SS exaust with Magnum Force air intake . Mag-Hytec Trans and Rear. 1991 Ford F150 Lariat Complete renovation. The truck is a DREAM gotta love it.
  #233 (permalink)
Old 01-05-2008, 06:22 PM
Old Ford Blue's Avatar
Old Ford Blue Old Ford Blue is offline
Old Ford Blue is starting off with a positive reputation.
Hey guys, just a quick question before I tear into mine. I am assuming that the actuators in the 97-03 F-150s are the same and that the procedure should be basically the same?
Thanks guys,
Gabe
  #234 (permalink)
Old 01-05-2008, 07:45 PM
To update my ratcheting sound. I took the old actuator apart, #8 Torx. The gear on the motor shaft had stripped teeth where the swing out engaging mechanism is. I switched ends of the gear and it should work. I bought a new one before i tore into it. I have an passenger side extra now i guess.
__________________
  #235 (permalink)
Old 01-16-2008, 05:17 PM
mr2000 mr2000 is offline
mr2000 is starting off with a positive reputation.
I am going to try this fix --but depending on how long it takes --Im wondering if I stop in the middle will my door close so I can drive around and finish later-----and do I need to take off the door handle....Thanks
  #236 (permalink)
Old 01-16-2008, 05:25 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
1999 Ford F-250
zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of
Don't think I would recommend starting and not finishing. You have to take everything that latches loose and if you were able to get it latched, it would be a pain in the a$$ to open the door from the inside with everything unhooked. It shouldn't that more than 1 to 1 1/2 hours, tops. My first one was about an hour and I had plenty of other stuff going on. Did it on a family camping trip with limited tools and nieces and nephews wanting to see and help with everything I did.
Edit: Forgot the door handle part. I choose not to remove the outside door handle and it did make unhooking and hooking a bit tougher but still wasn't bad. Others seem to think removing the handle is the best. So it is your choice.
  #237 (permalink)
Old 01-16-2008, 07:59 PM
Mad Max II Mad Max II is offline
Mad Max II is starting off with a positive reputation.
^^^^ I agree. When I did mine it only took about an hour and following the great instruction on this site everything went as planned.
Good to see another Barry out there
  #238 (permalink)
Old 01-16-2008, 08:04 PM
zx250's Avatar
1999 Ford F-250
Hmm, I had your figured for a Max for some reason..
  #239 (permalink)
Old 01-17-2008, 09:44 AM
tamte65 tamte65 is offline
tamte65 is starting off with a positive reputation.
Quote:
If you have handy, long and not too thick fingers, you should be ok W/O taking the handle off.
It took me 2.5 hours to do all the four doors.
In 100*F heat, 1 hour went with the first door, figuring it out and getting all the right tools, drills and screws etc.
The rest then went like 30 min each, even with the beer breaks every 5 min.
=> So you need sixback per each door? No, I think I had one beer per door.
__________________
Stroking South Texas
F250 -00 PSD 4x4 CC SB Lariat A/T, 151k.
  #240 (permalink)
Old 01-17-2008, 12:21 PM
I finished one----it seems to be working fine-----EXCEPT THE LIGHT ON THE REAR OF THE CAB SHINING ON THE BED DOESNT ALWAYS GO OUT WHEN I CLOSE THE DOORS---IM SURE ITS A SENSOR OR SOMETHING------BUT I DONT KNOW WHERE OR HOW IT WORKS----CAN I IDENTIFY IT FROM THE PICTURES PEOPLE PUT UP ON THIS POST ????????(my dome lights are out or they probably would be on too) Thanks
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
