Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #211 (permalink)
Old 09-24-2007, 01:35 PM
largefries's Avatar
largefries largefries is offline
largefries is starting off with a positive reputation.
Yeah, I did the actuators back in Feb. Then both locks stopped working a couple of months ago (both at the same time time).
  #212 (permalink)
Old 09-24-2007, 03:49 PM
largefries's Avatar
found it, thanks kalsc. Replaced and still the same. Damn! I guess I'm pulling the actuators out again to test.
  #213 (permalink)
Old 09-27-2007, 05:37 AM
NC Deere NC Deere is offline
NC Deere is starting off with a positive reputation.
Thumbs up
New to the forum. Did mine last night both sides in about an hour and a half. Thanks for all of the great description and photos. Boy they pop great now.
  #214 (permalink)
Old 09-27-2007, 02:24 PM
jjbirish jjbirish is offline
jjbirish is starting off with a positive reputation.
SO EVEN SOMEONE WITH TWO LEFT THUMBS AND ARTHRITES IN THE OTHER FINGERS SHOULD BE ABLE TO PULL THIS OFF...
SOMEONE LIKE ME...
both rear doors on mine quit working...
  #215 (permalink)
Old 09-27-2007, 03:04 PM
I can fix about anything but this was truely easy. Just be careful taking the end of the motor off and getting the brushes spread out to fit against the armature.
  #216 (permalink)
Old 09-29-2007, 05:23 PM
Arizona SD 250 Arizona SD 250 is offline
Arizona SD 250 is starting off with a positive reputation.
Is there a lock to let down the chain for my spare tire? I'm having trouble trying to use the tool it works with.
  #217 (permalink)
Old 10-11-2007, 02:04 PM
largefries's Avatar
Ok, took the motor out of the assembly and it is toast! Did the fix and it worked for a while, but both stopped one day. Now the motors look like they got so hot it melted the little gear on the end (and everything is black and melted on the inside too). I guess I wasn't careful enough putting the motors back together. My only guess is that I bent the arm holding the brushes, which short circuited the motor. I'm going to try to find some at a wrecker and guessing all the superduty trucks and vans 99 and up are the same? Does anyone know if the motor itself is available from any suppliers?
  #218 (permalink)
Old 10-15-2007, 09:38 AM
cboland cboland is offline
cboland is starting off with a positive reputation.
Fixed passenger side this morning and only took about 1/2 an hour. I did the same thing as the original post (took EVERYTHING apart) but didn't notice the thermistor. Wrapping it in foil solved the problem.
Here are some other comments I'll add. I first noticed the passenger door not working, then slowly the drivers door was failing too. For some reason if one actuator fails it effects both doors (since my drivers lock is working fine now too).
When putting the actuator back together all I had to do was remelt the plastic tabs. I used a torx bit, applied some heat and remelted the tabs to the holes.
One more note, take care wrapping the thermistor with foil. You dont need much as you are only making an electrical short circuit, not wrapping an Xmass present!
Test the motor BEFORE you put it back in the actuator housing. Spin it by hand. You shouldn't hear any noise and the gear should spin freely. Apply 12vdc and make sure it works without letting the smoke out or getting hot. Reverse the polarity and make sure it spins the other way too. Then reassemble everything and you should be in business.
  #219 (permalink)
Old 10-19-2007, 10:48 AM
Derek M Derek M is offline
Derek M is starting off with a positive reputation.
Glad to hear of something like this as my 99 F350 has three locks that work occasionally. Will try this this weekend. Thanks
  #220 (permalink)
Old 10-21-2007, 03:06 PM
gtadim gtadim is offline
gtadim is starting off with a positive reputation.
How do you open the door panel on a 2000 excursion to get at the door lock actuator?
gtadim@can.rogers.com
  #221 (permalink)
Old 11-04-2007, 05:41 AM
iostream iostream is offline
iostream is starting off with a positive reputation.
It's on the like 3rd or 4th page but they said to pop off the switch control plate and remove the reflector and the whole thing lifts off...if it is a front door there is another screw or something opposite the mirror...but check early on in the thread after the pictures of the lock mechanism someone posted.
  #222 (permalink)
Old 12-05-2007, 06:14 PM
tow123trk tow123trk is offline
tow123trk is starting off with a positive reputation.
to get the actuator out do u have to get the latch out?
  #223 (permalink)
Old 12-05-2007, 06:25 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Check the tech thread it gives all the details.
  #224 (permalink)
Old 12-13-2007, 12:37 PM
G BOBKA's Avatar
G BOBKA G BOBKA is offline
G BOBKA is starting off with a positive reputation.
I did the powered or lock fix. Everything works great.My only problem is, everything works backwards. When I put the motors back together. There is a little window, though it's actually not a window, I guess you're supposed to put it back together, as it came apart. But in order for me to make sure the brushes were seating properly. I spun the motor. 180°, so I could see. Is that why everything is working backwards? Everything works fine it is just that the unlock and lock on the door and on the hand piece are backwards. What did I do wrong?
__________________
2000 Ford F350 XLT 7.3 4x4 Amsoil Bi-Pass with Amsoil through-out . Chiped with piller gauges(EGT,boost and trans).4"SS exaust with Magnum Force air intake . Mag-Hytec Trans and Rear. 1991 Ford F150 Lariat Complete renovation. The truck is a DREAM gotta love it.
  #225 (permalink)
Old 12-13-2007, 01:00 PM
vettdvr's Avatar
Quote:
It is working backwards because you put the motor in upside down which reversed the +/- connections. Open it up take out the motor and rotate the motor housing 180 degrees and reinstall it should work correctly.
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
