Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #196 (permalink)
Old 08-13-2007, 12:30 PM
19stroker99 19stroker99 is offline
19stroker99 is starting off with a positive reputation.
Talking door locks
I did the .02 fix om my 99 f250 this week end worked great thanks for the fix
great site.
  #197 (permalink)
Old 08-18-2007, 11:02 PM
tenn250 tenn250 is offline
tenn250 is starting off with a positive reputation.
Tried this on both of my doors. It worked great, long enough for me to get everything put back together, then the driver side just died all together. Had to pull everything back apart, tried to get it to work, but was completely kaput. Went and bought an aftermarket actuator and put that in. The pax side is still working for now, but I'm a little concerned it too will fail at some point. Oh well, if it does I guess I'll just replace it too. For now seems to be doing fine.
It did take a considerable amount of time to do the first one. But now I can have the thing out and replaced, and panels back on in around 30 minutes. Not sure why that one shut down, seems most everyone else is having great luck. Definitely a good post.
  #198 (permalink)
Old 08-18-2007, 11:52 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
1999 Ford F-250
zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of
Well, I don't know if it will make you feel better or not, but mine has been done of 16 months now and still sounds new.
  #199 (permalink)
Old 08-20-2007, 03:25 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Could be defective motor,, bad brushes, gears didn't mesh correctly,, low brush tension. This is a good repair but even with the repair it is possible to have failure. My repaired have been over a year now and still going strong. I bought 2 before I found how to repair and the 2 factory will probably fail before the repaired.
  #200 (permalink)
Old 08-26-2007, 03:23 PM
fiveohpatrol fiveohpatrol is offline
fiveohpatrol is starting off with a positive reputation.
yet another fix here, thanks!
  #201 (permalink)
Old 08-26-2007, 09:18 PM
hrsepwr2 hrsepwr2 is offline
hrsepwr2 is starting off with a positive reputation.
actuator fix
Good info...
  #202 (permalink)
Old 08-26-2007, 09:33 PM
16.7:1's Avatar
16.7:1 16.7:1 is offline
16.7:1 is starting off with a positive reputation.
Same thing happened to mine. I got it hooked back up and the lock worked but I noticed a puff of smoke. After a couple of tries and and some more smoke it died all together. Had to install a new unit.
  #203 (permalink)
Old 08-27-2007, 10:42 AM
vettdvr's Avatar
Quote:
All electrical equipment comes with smoke built in,, when you let it out they quit working.
You really have to be careful installing the thermistor and insure the brushes are correct. Small details here will let the smoke out.
This is why I now use the $.01 repair or the 18 ga. copper wire soldered around the end. It is a very clean installation and helps to keep the smoke it. Jim
  #204 (permalink)
Old 08-28-2007, 10:25 AM
The smoke thing is funny. My passenger actuator is still working, I did them both the same. I will admit I wasn't ablt to get the little tabs on the elect. motor back down, but I hoped the snug fit would hold it together within' tolerance. Oh well, guess one held and one didn't. Still saved me 60 bucks.
  #205 (permalink)
Old 08-28-2007, 10:42 AM
vettdvr's Avatar
If you don't bend the tabs back down the end bell and brushes won't stay in place. I use a used dental tool for this job. High grade steel very small works well. I think you found your problem. Jim
  #206 (permalink)
Old 09-01-2007, 09:41 PM
TTFord07 TTFord07 is offline
TTFord07 is starting off with a positive reputation.
Ya, thanx for the info guys its works, but the whole process is a pain in the ass, gotta love ford though, who would have thought it was that easy of a fix, after u spent the time tearring it apart.
  #207 (permalink)
Old 09-23-2007, 01:18 AM
bigtexan99 bigtexan99 is offline
bigtexan99 is starting off with a positive reputation.
problem now reversed
Did the fix on my Drivers door today. Now it works great with the remote, but I could not figure out how to attach the linkage from the keyhole lock back to the actuator.
It was getting dark so I put it all back together.
So now, I can unlock the door with the remote, but not the key.
Can anyone provide instruction on which way that goofy piece of metal with all the twists is supposed to attach? A photo would be nice. I tried it every which way.
Thanks! I'm in Portland, OR right now...anyone around here that knows?
__________________
1999 F250 SuperCab PowerStroke 7.3 2x4
230k miles and rolling strong. 17/19 mpg
Muffler and CC delete
A/C heater core mod
boost, tranny, egt gauges
5th Wheel - 34 foot Jayco Designer XL
  #208 (permalink)
Old 09-24-2007, 11:43 AM
kalsc's Avatar
kalsc kalsc is offline
kalsc is gaining momentum as a positive member of FTE.
That's 100 percent correct, you have to be quite careful when you re-assemble otherwise it will burn out on you. As stated above, attention to detail and taking your time on this is key. I like the soldered wire idea, that would look much cleaner. Just thought I'd chime in and state that all four of my locks are still working 100% since I posted. Glad to see this has been so effective for so many people. Cheers! KALSC
__________________
99 F250 Crew, 01 Engine/Computer, 8" lift, 38" Trxus STS, 5.38 gearing, Kwik Filter, 5.6K resistor Mod, TS 6 pos. Chip, 5" Stacks, T/C Lock, Wicked Wheel, FS2500, Gear Vendors O/D, BTS transmission, 6.0 Trans Cooler, Water Inj.
  #209 (permalink)
Old 09-24-2007, 12:22 PM
largefries's Avatar
largefries largefries is offline
largefries is starting off with a positive reputation.
Does anyone know where the relay would be for the door locks? I have had both quit at the same time, so I doubt it is the motors, its not the fuse, not the switches. I have checked the owners manual and it does not list a relay. I have checked alldata and it only says " in the center of the instrument pannel". I had the big cover off under the steering column and the stereo out, dug arround a bit, and couldn't find it. I can hear the ting of a relay when i press the switch, but can't pin point it. Has anyone had to replace one?
  #210 (permalink)
Old 09-24-2007, 12:51 PM
kalsc's Avatar
At first I thought it was my relays as well. I found mine in a box mounted on/near the firewall while reaching in from the stereo hole. All of mine went at once too which was very odd, but the fix was to jump the thermister in the lock motor, not the relays, in my case anyway.
__________________
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
