Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #181 (permalink)
Old 07-13-2007, 01:19 AM
taylormade99's Avatar
taylormade99 taylormade99 is offline
taylormade99 is starting off with a positive reputation.
Hey all. It's me........the original poster for the door lock fix! I haven't been on in a while. I just bought my wife an EX and low and behold ALL the actuators are terrible. I thought I'd get online and do some searching to "remember" how I did the fix and low and behold there are IMPROVEMENTS! I am doing the .01 cent fix tomorrow. I'm glad to hear it's helped out so many and saved $$$$
__________________
1999 (early) PSD F250 SC, 4X4, Auto
Sonnax, Coolant Filter, 02 Excursion (7.3 Powerstroke.....is there any other kind of motor?) No mods yet on the EX...coming soon.
  #182 (permalink)
Old 07-14-2007, 02:00 PM
Big Sky Big Sky is offline
Big Sky is starting off with a positive reputation.
I did mine on the lift gate on the Ex. It works with authority and all it cost was .01...
__________________
2002 PSD Excursion Limited 4x4, Mineral Grey. Hellwig Anti-Sway Bar.
2000 F-250 SC 4x4 V-10, Burgundy, Raven Topper
  #183 (permalink)
Old 07-17-2007, 02:41 AM
mindymom mindymom is offline
mindymom is starting off with a positive reputation.
Taylor how far are you from Portland Oregon LOL. I have 1 door lock out, rear driver side of my F-350 CC. I'm going to try and get me hubby to fix, we'll see. Thanks for the great info.
  #184 (permalink)
Old 07-17-2007, 11:40 AM
I'm about 7 hours away.........But if I was down in Portland I wouldn't be any use anyway........You couldn't get me off of the mouth of the Columbia River..........SALMON FISHING!
Good luck with the door lock! I'm glad it's helped so many people. That's what this forum is all about.
__________________
  #185 (permalink)
Old 08-05-2007, 10:20 AM
peter p peter p is offline
peter p is starting off with a positive reputation.
I removed my 2003 f150 supercrew rear door actuator and it looks nothing like the pictures of the ones you have here.
Will this fix work on the 2003 supercrew or do I have to buy a new actuator?
  #186 (permalink)
Old 08-05-2007, 04:09 PM
Well the actuator looks different but the parts inside are the same.
I opened it up a little differently and did the fix and all is good.
  #187 (permalink)
Old 08-05-2007, 09:31 PM
FastCote's Avatar
FastCote FastCote is offline
FastCote is starting off with a positive reputation.
I just did the two front doors and a 2000 Windstar. Wasn’t sure if the actuators would be the same, but my symptoms matched so I gave it a try. Worked like a champ!! I used Gorilla glue to put the actuator back together. Good for now, hope it holds...
NEW OPTION: I used a short piece of 12 gauge copper wire (the bare neutral wire from a piece of Romex house wiring). I just bent it over to make a tight U shape and then beat it with a hammer to make it slightly thinner.
Hope I get a few years before the ’05 F350 needs this treatment.
__________________
http://i304.photobucket.com/albums/n...Toys_small.jpg
2005 F350 Harley: Heat Induction Hood, ARE Bed Cover, DashHawk, MBRP turbo back, cat delete, SCT: Tunes by Spartan, Exhaust Sound Videos HERE
http://callsidehire.com/truck/Toys_small.JPG
  #188 (permalink)
Old 08-07-2007, 07:38 PM
tomsash tomsash is offline
tomsash is starting off with a positive reputation.
Thanks this post saved me 50 bucks and worked great
  #189 (permalink)
Old 08-07-2007, 07:50 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
1999 Ford F-250
zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of zx250 has much to be proud of
Yes, I think it has saved a bunch of us here some money. Take a second and leave kalsc a few rep. points. He's the one that started the link and fix.
  #190 (permalink)
Old 08-09-2007, 12:55 AM
largefries's Avatar
largefries largefries is offline
largefries is starting off with a positive reputation.
I did this fix, it was the best! I was giddy everytime I used them. BUT, now they just stopped working alltogether. The fuses are fine, is there a relay or something?
  #191 (permalink)
Old 08-09-2007, 09:25 AM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Quote:
Check Fuse #26 in the power distribution panel on the Left side of the engine top front of wheel well.
Remove and replace this fuse. Check your model my records only go to 2000 but it should be in the same place. This is the only thing that prevents power to your locks other than a dead battery, broken wire or defective window switch on the drive door. All power goes to the driver door then to the pass door. I assumed you have a 2 dr F250. If it is a 4 Door all is the same but more actuators
So replace the fuse with a new one and try again.
  #192 (permalink)
Old 08-10-2007, 02:10 AM
largefries's Avatar
Just checked that fuse with multimeter and its good. So I guess I'll check the the driver door connections. The windows all work. It is a 200 250.
  #193 (permalink)
Old 08-10-2007, 08:54 AM
vettdvr's Avatar
If your fuse is good you should have 12 volts at the window switch between pins 4 and 1,2,or 7. Pin 4 is the 12 V in 1,2,7 are the grounds. If you don't have power on the switch look at the power lock relay.
On some trucks there is a power lock relay in the relay box mounted on the fender. Look in your owners manual and find out which relay sends power to the lock switch. Replace this relay then check.
  #194 (permalink)
Old 08-11-2007, 12:33 AM
largefries's Avatar
I check the owners manual and no relay is listed for the door locks, only the auto roll down feature. I checked all the pins at the window switch and none had 12v, but the lock switch does have two pins with 12v, power is getting to them. So, I checked the switches themselves and they work. I'm guessing power is not getting to the acuator somehow? or something at the actuator has come off. I'll take it out tomorrow, its getting dark here.
  #195 (permalink)
Old 08-11-2007, 04:33 PM
Unclemuck's Avatar
Unclemuck Unclemuck is offline
Unclemuck is starting off with a positive reputation.
Just did my pass door. Been bad for a year. Kickin myself for not doin it sooner. Cake! Thanks
__________________
2001 Limited
V10
295 BFG KO's
ZooDad mod
Pioneer / Infinity sound system
window tint
Silverstars x 4
Helwig rear
4 wheel junkie light bar with 4 Hella 500'S
"The Mobile Billboard"
Tags
1995replace , 2000 , 2001 , actuatorf150 , door , f250 , f350 , ford , lock , locks , power , problem , resistor , thermal , truck , type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
