Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-07-2006, 06:36 AM
69crewcab is starting off with a positive reputation.
8 lug wheels
Group
what years of 8 lug wheels will fit a 78 f-250, i know the 60's and 70's ford and dodge will...What about them in the 80's??
If i remember right Ch*vy uses a different rim on there dana axles..
__________________
Joe
Tried, True and Ford Blue.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-07-2006, 08:02 AM
firstonraceday's Avatar
firstonraceday is starting off with a positive reputation.
If I'm not mistaken, on 16" wheels, a Ford 8-Lug wheel through year model 1996 should fit. All those years should have the 6.5" spacing on the lugs. Since that time, the wheel lug spacing has been metric.
If this isn't correct, I know someone else will chime in with the right answer.
__________________
Jason
2005 F-150 XLT SuperCrew, 5.4 w/Auto, 3.55LS
1993 F-150 300 I-6 w/5-Speed (Traded for the above 8/6/2005)
1977 F-250 351M w/T-18 (Rebuilt at 315,000 Miles)
2008 Escape Limited w/3.0L V-6 (Wife's)
  #3 (permalink)
Old 01-07-2006, 09:07 AM
armstrongfordtrucks is starting off with a positive reputation.
wheels
I went to a junkyard to steel wheels 1986 f-250 ended up with wheels that had used 9/16'' lug, be careful make sure you specify weather you have 1/2 or 9/16 cuz these loosers would not exchange them. Thats right I no longer go there. I bought lots of parts from them to.Ended up buying EAGLE wheels at a local shop here 395.00 wth lugs and centers.
Have a great day
ARMSTRONGFORDTRUCKS
  #4 (permalink)
Old 01-07-2006, 04:50 PM
robtinalimon is starting off with a positive reputation.
I can fit HMMWV wheels on my truck, if only I had the lift..
  #5 (permalink)
Old 01-07-2006, 06:06 PM
ivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud ofivanribic has much to be proud of
Chevy still uses the same 8x6.5" lug pattern (H2 rims look bling and are pretty cheap if you want some nice looking rims) and I believe Dodge does to. Ford changed in 97 to a metric pattern and I believe a hubcentric system. Pretty much all the 8 lug rims you find out there will fit unless they specify that they're for a 97 and later Ford truck.
I've never seen a wheel that wouldn't fit due to variances in lug size (3/4 ton used the half inch studs while 1 ton used 9/16) but I suppose anything is possible. Your lugnuts for the 1/2" studs shouls still have had plenty of tapered seat to center the wheels just fine.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
