99 Ranger Transmission fluid - how much does it hold? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-06-2006, 08:16 PM
RangerBiff RangerBiff is offline
RangerBiff is starting off with a positive reputation.
I have a '99 Ranger, 4.0 L, 4x4. I'm changing the transmission fluid and filter myself because everyone wants a fortune to do it. I live in San Francisco and to get anything done here costs a lot of $$. I don't have the owners manual. How much fluid does the tranny and transfer case hold? Is the torque converter the same as the transfer case? Maybe I'm mixing up terminology. Thanks!
Old 01-06-2006, 10:14 PM
Dave257 Dave257 is offline
Dave257 is starting off with a positive reputation.
A full fluid change on the transmission takes about 10 quarts. The transfer case takes about 1.25 quarts. The torque converter is part of the transmission and not the transfer case. If you drop the pan you will only change a small part of the transmission fluid. To change it all requires pumping it out of the transmission. It runs about $80.00 at a transmission shop and about $130.00 at a dealership in most areas around the country.
Dave
Old 01-07-2006, 06:13 AM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
The 5R55E tranny holds 10 quarts totally dry, including the lines. Dropping the pan will remove about 4 quarts or so.
FORD 4R/5R55E Transmission Fluid, Filter & Gasket Change
Is there a seal on the tailshaft housing of the C6 on a 4x4? CountryBumkin 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 08-22-2014 12:42 PM
NP205/C6 Transmisson esidneyw 1973 - 1979 F-100 & Larger F-Series Trucks 23 02-13-2014 06:51 AM
Front/Rear Axle and Transfer case oil change questions? bigblockford_390 1999 - 2003 7.3L Power Stroke Diesel 4 03-11-2012 01:58 PM
Fluid types and levels.... howse Ranger & B-Series 9 06-11-2007 09:44 AM
ZF 5 speed and transfer case fluid BGFNRED Clutch, Transmission, Differential, Axle & Transfer Case 6 08-16-2005 07:03 PM
Tags
1991, 1996, 40, 4x4, 99, atf, capacity, case, change, fluid, ford, hold, ranger, transfer, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
