01-06-2006, 06:42 PM
Starting over IS my style
the bed bolts need to be replaced, but a quality kit should include all the proper bolts. An extension rod(flat) is used for the C6 shifter. I removed the fan shroud and left the rad. where it is. I snipped a little more sheet metal off the cab floor where the tcase shifter hole is. rebent the brake lines to the master cylinder. loosened the filler neck on the bed and slid the hose parts down a bit. redrilled the rear bumper mount brackets, and fabbed the front bumper to clear the grille shell. using concrete blocks and a bottle jack, I lifted the cab and bed up just enough to slip in some short chunks of 2x4's. until it was level, then slipped in the body lift parts and lowered each end back down. Wasn't real hard. I did it 13 years ago and haven't had a problem since.
__________________
Game On!
The Good1948 F1: awaiting an S10 T5 tranny
The Bad1987 TC: awaiting funds for parts
And the Ugly1962 Fairlane: awaiting everything
