Can I make my 7.3 PSD quieter?
Are you wanting to quiet the exhaust or engine noise? I assume you are talking about engine noise.
The IH "Blue CPS" is supposed to help queit them down and smooth things out, as well as improve MPG. Here'a a link or two about it:
https://www.ford-trucks.com/forums/s...d.php?t=446151
https://www.ford-trucks.com/forums/s....php?p=3251330
Also, replacing the quick connects on your fuel line from the tank to the pump will help. A lot of air gets sucked into the lines at those quick connects, and can cause noise. You'll want to cut off the quick connects and replace with a hose. See this link: https://www.ford-trucks.com/forums/s...d.php?t=446151
There may be some other ways, but others will need to chime in for those.
Originally Posted by Bird Dog
Is there any other mods beside the HPX line mod that will quiet my 7.3 down. The 6.0 is nice and quiet. I do use Rotells 5/40 syn, and that helped. Thank you!!!
i put the plastic sound deaders on and they seem to help. its been a long time but the parts were off of a newer ford mine is a 99. the one on the driver side is only held on by 1 bolt but been there 4 years ok. also the up pipes on mine are starting to leak and i will be doing them soon as it warm up. i can hear them and you need a good light and look at the end that is way up and into the top if there is soot they are leaking
Originally Posted by Fordafied
There is a guy that I know (on-line) that swears his idles and runs like a sewing machine. I have never personally heard it. It has everything to do with programming with injectors, timing, pulse and a few other things that I can't quite remember. PM me if you want to know who and where. I will not post it on here.
If you are talking about interior noise, there are sound dampners that can be intalled inside of your cab. Basically, you remove the interior carpet, and they are like "plates" that cover your floor pans and fire wall. I am sorry but I cannot remember where I saw them online at.
Also, Ziebart can apply a heavy undercoating they call a sound dampner. Basically it is a heavy layer of undercoating almost twice the normal thickness.
I have heard of both of these remedies, but I have not tried either one of them, sorry.
I put stuff called "brown bread" sound dampening material in my Camaro which has a mild cam, SLP headers, Corsa exhaust and gutted cats so it's really loud. The "brown bread" is like heavy sheets of tar you cut up and stick on the bare metal after you gut your interior. Got it at b-quiet.com. I also put fiberglass insulation in areas that I could stuff it. You can do the same to your truck.
i did some research on noisy truck engines.turns out if you can not handle the noise of a diesel engine here are some tips:dont buy it;if already bought bring back to dealer and get a gas engine.third choice is to buy a car.i am baffled how people can purchase a product and then complain about it.dont people road test and check vehicles out before buying them?
