My chain saw oiler won't work
My chain saw oiler won't work so I cleaned it out and stuck a wire in the hole and cleaned the screen on the pickup tube and tried blowing it out with compressed air but nothing. It doesn't have a pump button so it must be a automatic oiler. It's a Partner Pioneer. I think Model 7000. Any ideas? Tom
This Thread may soon experience TTR (Thread Topic Relocation). It is a phenomenon here at FTE for which nobody can explain. One moment your thread is there, then moments later it is gone. The most popular theory for this phenomenon is linked to alien abduction. It is said that after abduction, your thread is subjected to various forms of scientific testing. Many say that alien microchips are planted in your thread, giving the aliens the ability to change text, smileys, and on rare occasions, the actual subject matter. Do not fret however, it is said that the aliens will send you a secret message explaining where you can find your thread. Once you and your thread are reacquainted, you will find that your thread has no real recollection of the ordeal, only vague anomalous memories......
On a Partner 7000, if you need a new oiler, you better hope to find a good ole dealer with a stash of parts for that model, since PArtner was bought out by electrolux, and is now a poulan like thing. have you checked the screen in the oil tank? how about for kinks on the oil hose, or possibly something not allowing the pump gears to turn.
Lots of chain saws use pressure in the oil tank to push oil out thru the line to the chain. The pressure is created by crankcase pressure in some instances. I don't know about your particular saw, but if you are not getting a good seal at the fill cap, then you lose pressure buildup. Try to pressurize the oil tank and see if you get oil at chain.
I used to have an old 'Mac' chainsaw and the manual oiler wouldn't work. I kept a 3 lb. coffee can 3/4 full of used motor oil and every few minutes I'd stick the chain bar in the oil. Be careful if reving the saw not to hit the side of the can (leak, leak), and if reving the bar in the can watch out, cause it will throw oil pretty far.
on
1 Post
-Matt
