You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I read somewhere, possibly here that one can blend relatively small amounts of SVO into a tank of diesel, actually improving fuel quality and lubricity. I think the writer recommended blending a gallon of SVO in with a tank of conventional fuel. Not much but if it is actually a benefit to the engine and fuel mileage I would like to try it. I have access to some fully refined product (corn oil,soy) at no cost. Since I read about this I have been eyeing the price of SVO at the store and would not consider buying it costing 3-4 times that of diesel. The price of Powerservice is also getting a little out of range and maybe with this I could at least replace some of the lubricity factor needed. I am hoping some of you diesel heads out there may have some experience/feedback on this idea.
If all you are wanting to do is replace the lubricity that has been lost by the switch to low sulpher fuel, then you only need about 2% VO, but you can run 100% veggie oil if you are so inclined.
Thread moved to proper forum.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
Be sure to filter to 5 microns to get thru filters. If you have any engine warranty left. Ford might decline warranty if it involves a fuel issue. unless the veg oil is an approved fuel additive. Been thru testing- not home brew.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
I would like to run the truck on SVO but I don't have access to quite that much and I understand that you need to modifiy the engine to accept it. I am also much too paranoid about screwing up my precious truck. Our Ag Dept. at work retains samples of fully refined oils for a certain time and then disposes of them. I just though I might dispose of it into my fuel tank a gallon or two at a time. I think I'll research the net some more to see how much I can safely add without any modifications.
Sounds like a good idea. If "fully refined" means filtered, I don't believe I would worry about it only using a couple of gallons at a time. Just pour it in and go.
__________________
Scott
I have experience in blending veggie with diesel fuel in a unmodfied truck.
Adding a litre of veggie oil into a tank of diesel adds alot of lubricity to the oil and definately good for the engine.
Personally I wouldn't exceed a 20% ratio even in warm climates. Some run 50/50 which I have back in August but even in Dallas I've noticed unburnt fuel coming out the pipe in the form of white smoke even while the truck is fully warmed.
There is no need to filter SVO - Virgin oil as it shall already be clean if your buying it off the shelf. As far as WVO - Waste oil that should be filtered AND dewatered to at least 5 micron.
If you want to run 100% then you'll need to modify the fuel system.
OR if you want you can just buy Biodiesel at the pump and run with no modifications; According to your location your in Houston, follow the link below for a list of retailers in the Lonestar.
As RC said no need to modify the engine just need to tee into the fuel system. Once the truck is setup, running WVO is a great alternative to diesel. I run my 05 PSD on WVO. Over 8000 miles since conversion.
I'd say if you can get enough WVO go for a conversion, much simpler then making bio. Also will be cheaper in the long run.
Erick Panger LESK WVO Conversions
2005 F250 PSD
Plant Drive Two tank WVO system.
Hotstk, Vormax, A1000 and Vegtherm
I appreciate all the good info. I have a good source of Bio feedstock but not a lot of time and a very rambunctious 2-yr-old son that might find the operation (which involves caustic) very interesting. Purchasing Bio here is expensive and really inconvenient but that is soon to change. Soon Houston will be Bio-Central as 4 large plants are going in right now that I know of involving some big players such as Stolt-Nielsen and Dow Chemical. I will share that I read a post on the web last nite that claimed there is a danger of separation at cold temperatures and beleive it or not it does get cold down here in the winter. The writer did not specify temperature but had experience with the SVO stratifying to the bottom of the fuel tank during cold conditions. That would be a pretty easy home experiment to prove in a clear bottle and a refrigerator I would think.
Well people say depending on the feed stock that was used for the Bio, B100 gets thick at 40 degrees. I will say I have the same thoughts on making bio with the chemicals involved and is the main deciding factor in why I started with a conversion.
Now after having to take my Excursion in for common problems addressed on the forums, I'm reluctant to finishing the conversion on my Excursion due to warranty purposes. With that being said I'm personally going to start brewing Biodiesel to run in the Ex, Ford may say 5%, but it'll be alot easier to hide running Biodiesel when taking in for Warranty work, that and I don't have to be as picky with the oil, I'll taking the bacon grease and use that as well. In my area I tend to find quite a few people using lard which I've had to turn down. So I suppose it all balances out.
The great thing about getting into WVO, is I already have just about all the componets neccessary to make Bio.
I guess I'll have the best of both worlds. Can't wait till the Sheriff comes knocking on my door thinking I have a meth lab going on, that'll be neat
It'll be the SWAT team. Who would visit if they suspect.
__________________
B5 soydiesel user
Sirius radio
And they won't knock....they'll just kick the door in.
__________________
Scott
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
