Vibration when starting from a stop...!!!
01-04-2006, 10:46 PM
on
Its noting real big to me but every time it makes me think "What the %#@$ is that?" When i start out from a stop there is a vibration in the rear of my 2000 F250 4x4 7.3l. Weather turning or straight theres a vibration up untill i hit 6-7 MPH. Ive checked u-joints and tires are balanced. What would cause vibration at such a low speed? Any thoughts?! Thanks
01-04-2006, 10:58 PM
Driveshaft alignment, center bearing adjustment up or down. Usually down.
01-04-2006, 11:07 PM
on
center bearing??? is that the bearing thats holding up the rear of the first driveshaft? Its got a 4" lift....btw
01-04-2006, 11:08 PM
Unless you adjusted it when you did the lift it needs it now.
01-04-2006, 11:12 PM
on
is that the correct part tho? i bought the truck with the lift on it....sounds like you can drop that bearing, how? longer bolts, spacers?
01-04-2006, 11:14 PM
They make all the parts spacers etc. Special brackets, do a search with the lift manufacturers...I'm sure tomorrow someone will help out..
Dick
01-04-2006, 11:15 PM
on
ill find somthing....thanks for the leads!
Mattcavett
Modular V8 (4.6L, 5.4L)
05-19-2015 09:11 AM
jmolin
1999 to 2016 Super Duty
02-23-2007 03:14 PM
wesayso
General Automotive Discussion
11-24-2005 07:14 PM
Geoboy
Modular V10 (6.8l)
12-14-2003 10:58 PM
