superchip codes P1211/P0603 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-04-2006, 02:11 AM
mick9 mick9 is offline
mick9 is starting off with a positive reputation.
Can anyone give me the dumbed down answer to these two codes, I have the superchip manual and it gives P1211: ICP not controllable-pres above/desired. P0603: Internal Ctrl Mod KAM error. The truck is a 03, 7.3L auto running on max setting with pryo, boost and trans gauges and a 4" exhaust.
I guess the real question is am I damaging the truck when the engine light comes on. (Pryo stays resonable cool, 425c post trubo)
Thanks Mick
Old 01-04-2006, 05:29 PM
Thanks Mick
Old 01-04-2006, 06:38 PM
wlihntr's Avatar
wlihntr wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
just about anytime you add a tuner or programmer to the 7.3 psd those codes will come up...dont worry about them as long as the truck is running ok. simple enough
Old 01-04-2006, 08:42 PM
cookie88's Avatar
cookie88 cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Neither one are a problem, both are set by the programmer. No damage is being done.
800f post turbo is not bad, what's the boost doing when the CEL comes on?
Old 01-04-2006, 08:48 PM
cookie88's Avatar
Threads merged.
DTCS codes P1211, P0603, P1280 lstitt Australia Chapter 10 12-22-2015 03:43 AM
ran codes what do they mean? awillo0406 1999 - 2003 7.3L Power Stroke Diesel 20 05-07-2013 03:58 PM
loss of power on the high end teamwizard 1999 - 2003 7.3L Power Stroke Diesel 6 10-14-2007 02:37 PM
help with obd codes bigbadwolfe 1994.5 - 1997 7.3L Power Stroke Diesel 24 06-13-2007 08:32 PM
codes anybody? sneak 1999 - 2003 7.3L Power Stroke Diesel 7 01-24-2006 10:09 PM
Tags
73, code, codes, controllable, f250, ford, fte, icp, listing, manual, p0603, p1211, powerstroke, superchip, superchips, superchipscode
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
