Ranger foglight replacements (Not Ford OEM)
I put a set of aftermarket foglights on my truck a few months ago. The right side took a nasty rock and cracked the lens. However, the left one rusted apart in a rather short amount of time. I want to replace them with something a ton brighter and that will last a good long time instead of having to replace the entire unit. That is somewhat annoying. If anyone could recommend a good set of bright foglights please do so. Yes I am experienced in wiring and already have a switch installed. I plan on using that same switch as I already have a hole in the dashboard.
Thanks.
Thanks.
