Motor Trend says it is a V6....
Delayed due to Ford's financial constraints, the heavy-duty workhorse truck range is ultimately destined to receive major changes for 2007. This Crew Cab longbed 1-ton version sports a single rear wheel, and looks to offer a slightly larger cab area. Word around the office says this vehicle is being tested with a new, smaller V-6 4.5-liter turbodiesel sourced from International, promising improved fuel economy.
Great news, too bad it is not an I6 though....
There's an article in the latest Truck Trend which suggests that a version of that motor might make it into the F150 or next generation Expedition, but it's all speculation at this point. No surprise that it's a V6 given that it's basically a 6.0 with 2 cylinders lopped off. I suppose it's possible they could offer it in the bigger pickups, too, given that it's already being used in medium-duty trucks, but it would be another engine option, not a replacement for the bigger motor.
Boy, how spoiled are we?!?! It wasn't that many years ago that 200 hp and 440 ft-lbs would've been class-leading numbers in a diesel pickup! Not everyone's bread-and-butter is heavy towing, I'm sure a lot fleet owners and plenty of others could do just fine with the 6 as an alternative to a bigger diesel. Options! Since when were more choices a bad thing?
I hope that a 6 cylinder will not be the biggest offered in the heavy duty trucks. If Ford does that I think they have pretty slit there throat. What they need to do is improve on the 7.3. I did however like Jerme's idea. Replacing the 5.4 with a small diesel would be great step forward, not that the 5.4 is a terrible engine, but it sucks because has minimal pulling power and maximum fuel consumption and it really is not worth it. I have 4x4 supercab witha 5.4; I can only imagine what a slug 4x4 crew cab would be with the 5.4.
