Bridgestone Dueler A/T Revo ?'s
I'm looking at maybe getting some Bridgestone Dueler A/T Revo tires. Are you guys that have used them happy with them? Where is the cheapest place to but them? Their $175 a piece on TIRERACK.com. The one thing I don't like is there is no road hazard warranty available. I need some advice on this tire or something else as soon as possible. I need to get tires bought this week because my factory Pirellis are just about gone. Thanks!
They could be the best truck tires for wet roads, much better than my Wranglers before. One thing I noticed is that because of its tread, gravel and small rocks will stick in at low speed (I drive quite a bit on such roads) and will dislodge at higher speed. Discount tire does offer road hazard warranty, and their prices are reasonable.
They are mostly a brick & mortar outlet, but they do have a website, www.tires.com. However, I don't see Bridgestone/Firestone products on their website, even though I got my set of Revos from one of their stores barely a month ago.
In any case, in my opinion, it's best to get a tire from a local store or chain because that makes handling warranty or road hazard problems much easier.
I am on my second set of dueler A/T revos. The first set was on a truck that got wrecked. These are pretty much the best tires I've ever had. I got mine at Costco for about $115 a piece installed. The size was LT235/75R15. The LT tires were about $10 more than the P rated tires. More load carrying capacity.
38/38 here with a 1/2 ton. Note well, the attainable mileage depends a lot on alignment, and the type of axle you have. With my previous set of tires I didn't rotate them for a long time (like 40k ) but then it was too late. Because of the TTB axle, I got a wear pattern that looks similar to a badly overinflated tire on the front tires. (I run 40/40 with the previous tires, 5 psi over the manufacturer's recommendation) With these, I'll rotating them whenever I do an oil change (~5,000 miles) so hopefully they will wear more evenly.
Jkelley
12-18-2013 11:29 AM
JPeacock212
1997-2006 Expedition & Navigator
03-22-2004 08:07 PM
