Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Alberta Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Hallworth
  #1 (permalink)
Old 01-02-2006, 05:23 PM
WIREPULLER's Avatar
WIREPULLER WIREPULLER is offline
Garage is empty, add now
WIREPULLER is starting off with a positive reputation.
Question Need to change bolt pattern
Hey guys, I'm currently working on an old 79 CC shortbox, and I salvaged a disc rear end out of an old lincoln. I want to get the 5x5 axles, and rotors redrilled to the 5x5.5. Where can I get this done in Edmonton? I don't necessarily need a name of a place, just an idea where to start calling.
Thanks.
WP
__________________
"Whether you think that you can, or that you can't, you are usually right."
- Henry Ford (1863-1947)
  #2 (permalink)
Old 01-02-2006, 05:38 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Any machine shop or specialty wheel shop
  #3 (permalink)
Old 01-02-2006, 09:50 PM
mustange70's Avatar
mustange70 mustange70 is offline
mustange70 has a good reputation on FTE.mustange70 has a good reputation on FTE.
I wouldn't use that lincoln rear if possible, they use an odd ball ring gear (its like 9.75, plus its only 28spline). The disc brake setup almost entirely bolts on to a truck axle (i'm am doing a rear disc conversion on my 82 flareside, well eventially, as i have all the parts), then use a rotor off the front of a 87-96 4wd as you only have to space out the caliper bracket with a washer or 2.
__________________
Cody, Calgary
AB
82' Flareside: 2/4 Drop, 350hp 351W, Custom interior
81' 250 mudder: home fabbed lift & dana 60 SAS , 450hp 400, 4sp/205, 38" tsl's
  #4 (permalink)
Old 01-02-2006, 11:17 PM
WIREPULLER's Avatar
Well, the reason I'm doing this is almost out of necessity. the wheels I got for the truck(20" wheels, yum, yum), require at least 1.5" of spacers with my current rear end, per side. The disc rear end is 2.25" wider than my current 9", so it fits better. Also, I have multiple center sections for a 9", will they not fit into the hole in the axle housing, as all 9" rears are created equal? I am gonna run out to the garage, and test fit one of them as soon as I'm done typing..LOL. thanks for the added info mustange70!!
WP
__________________
  #5 (permalink)
Old 01-03-2006, 11:30 PM
mustange70's Avatar
Ahh alright, i though you were going to use the lincoln third (i recomend you don't for the reasons i said above), i haven't actually checked myself personally but i believe that they are the same as far as interchangability among third members is concerned.
__________________
Cody, Calgary
AB
Tags
bolt, change, ford, pattern, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
