What wiper blade refills to go with? - Ford Truck Enthusiasts Forums
Old 01-02-2006, 04:55 PM
F150Texan's Avatar
F150Texan F150Texan is offline
F150Texan is starting off with a positive reputation.
Question What wiper blade refills to go with?
Nevermind, I called the auto parts stores, and it's a dealer item and they don't just sell the refills.
Just for future refernce to others, they are $13 a side.
Old 01-02-2006, 10:13 PM
edillen edillen is offline
edillen is starting off with a positive reputation.
I got the Bosch Micro Edge replacement wipers from a local auto parts store for roughly 10 bucks a pice and they work great.
Old 01-03-2006, 01:05 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
dealer only item? i think not. they are super common. trico is the oem maker they run 7.99 each. walmart sells anco for 3.48 each or pylon brand for 2.44. the pylon brand has been very good to me they clean well and are cheap and quiet.
Old 01-03-2006, 01:11 AM
ford uses basic wiper blades. so they are universal fit. most blade refills have 3 different types of mounting options. the parts store told you wrong.
Old 01-03-2006, 09:45 AM
Yeah, my originals only lasted about 9 months with hardly any use.
Old 01-03-2006, 02:25 PM
Dazz Dazz is offline
Dazz is starting off with a positive reputation.
Like Ford390 posted, Trico is a common shelf item in parts houses. The Trico 20-1 will fit my '04 RCab. Parts houses stopped stocking just the rubber insert because too many non-mechanics were getting the wrong insert and asking for replacement help. The Trico 20-1, or any other blade number costs little more than what rubber insert replacements used to cost.
Old 01-03-2006, 04:58 PM
Ulf Ulf is online now
Ulf is starting off with a positive reputation.
Advance Auto Parts has them, what you need is TRICO refill part # 45-200 thats the one that fit my 2004 F-150, it is just the rubber part, you don't need to replace the blade assembly. I replace them once a year.
Ulf
Old 01-03-2006, 10:26 PM
Toreador's Avatar
Toreador Toreador is offline
Toreador is starting off with a positive reputation.
Quote:
No Joke, Eddy. Mine were toast after 6 months and I rarely ever used them. I guess they had to "cut corners" somewhere.
Old 03-05-2006, 09:22 AM
kurtismayfield kurtismayfield is offline
kurtismayfield is starting off with a positive reputation.
Has anyone else noticed how wimpy the wipers are size wise?
My '05 screw came new with 20 inch blades on that giant sized windshield!
I now have a 26 inch on the drivers side and a 24 inch on the passenger side...what a difference!!
Old 03-05-2006, 11:04 AM
is300wrx's Avatar
is300wrx is300wrx is offline
is300wrx is starting off with a positive reputation.
I just replaced mine with the PIAA SPORZAs and they are AMAZING! It never streaks and its even has a built on spoilers on the blades to be more aerodynamic during high speeds. Anywho, best blades I have ever used.
Tags
2005, 45200, blade, blades, f150, ford, goodyear, length, refill, refills, size, trico, truck, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
