2000 Expedition blower motor resistor location - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-02-2006, 10:17 AM
jafare jafare is offline
jafare is starting off with a positive reputation.
Hi, I'm new to this site and was wondering if anyone out there has any information on the location of the blower motor resistor on the 2000 Expedition Also what procedure must be taken to remove it. It has a manual system and the blower only runs on high speed. Thanks!<!-- / message --><!-- no sigs except when logged in -->
Old 01-02-2006, 04:36 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
Look under the passenger side of the dashboard for the resistor. It should be located to the left of the fan motor. Tough to see, but it has a 4-wire harness running to it. It's screwed into a metal channel located behind the heater box. The box does not have to be moved or disassembled. The channel is sandwiched between the heater box and the uppermost area of the floorboard.
The mounting plate of the resistor should have a brown, almost pressboard-like appearance, and is held in place by two screws. It's about 1 x 2.5 inches in size. I actually resorted to using a small mirror to find it. If you pull the resistor, you'll see that it's comprised of four steel coils (look like large ink pen springs) attached to metal brackets.
Cost? About $16 at the dealer.
Old 01-02-2006, 05:17 PM
Thanks for your help, I had it out in about 5 minutes. It took awhile to find, but after following the 4 wires and using the small mirror it was relatively easy to remove two 5/16" hex head screws. After examining it I found where one of the coils was open at one of the metal brackets which were all almost rusted through!
Old 01-02-2006, 10:39 PM
By the way, if you're in a pinch and your Expy has the OPTIONAL rear heat + A/C system (vents in the ceiling), the resistor for the rear heat/AC blower is the same part. It's located behind the A/C system access panel on the driver's side cargo area.
Old 01-03-2006, 08:29 AM
My car does have rear heat/AC, but to tell you the truth, I hardly ever use it and haven't even checked to see if the blower motor is operating properly. Thanks for the info!!
Old 02-11-2006, 07:10 PM
ExpyBoy's Avatar
ExpyBoy ExpyBoy is offline
ExpyBoy is starting off with a positive reputation.
Anybody know if AutoZone or Advance Auto carries this part??? And what under their ever loving Computer System it would be listed under?? Spent 30 Minutes with a Kid at AZ with him running to the shelves and back to no avail
Old 02-19-2006, 08:14 PM
ExpyBoy's Avatar
Is this the Same on a 2001??? The entire Pass side has no Harness that resembles the one described...
Old 02-19-2006, 10:42 PM
ExpyBoy's Avatar
Since I can't find an Edit Icon???
I'm betting that Auto Climate is set up different... I have the Ford Repair CD and it shows the Resistor Installed IN the Fan Motor (in the Housing) with a Harness going from it to the Motor ....
After 3 hours of sitting up-side down (with 2 blown Lumbar Discs)... NO resistor in the Fan Motor Assy...
The CD even has a PICTURE but NOPE...
Anybody had to change one of these on an Auto Climate Control??? The Haynes Manual shows Wire Colors coming from the Combo Switch to the Resistor, those colors don't exist coming off the back of the Control Module...
If'n you see a small Mushroom cloud coming from Central VA... That'll be my Truck pretty soon
Old 06-05-2014, 12:02 PM
tribeone tribeone is offline
tribeone is starting off with a positive reputation.
Misleading
The repair manuals are misleading. The Expy blower motor resistor comes in two types depending on when and where made. the most common is this one
https://encrypted-tbn1.gstatic.com/i...59NRXg2blZ2gvA
But there is also this one
http://www.rockauto.com/getimage/get...x%2F4P1581.jpg.
I have the second one. an dit is located behind the passenger side kick panel.
Old 06-05-2014, 12:06 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
You realize that this thread was from 2006......
Old 06-05-2014, 12:11 PM
actually yea after the fact lol. I was doing a search because i have the same issue replacing this part and couldn't find any info.
2000 E 250 heater issues red rider #1 1968-2013 Full Size Vans 13 03-29-2016 11:38 PM
2005 Ford Escape Blower Motor Resistor tcoker79 Escape & Escape Hybrid 11 01-07-2016 12:36 PM
blower motor resistor location on an '87 E250 diesel? becida 1968-2013 Full Size Vans 3 07-26-2015 09:06 PM
No Power on blower motor, or fan speed switch Chuck Fuller 1999 to 2016 Super Duty 7 03-26-2015 05:47 PM
2009 e350 blower resistor e3506 1968-2013 Full Size Vans 1 02-16-2015 03:42 AM
Tags
2000expeditionfanresistor, 2006, 98, 99, assy, blower, bolts, disconnect, expedition, fan, ford, harness, motor, removing, resistor, runs, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
