Hey guys - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Hey guys
Old 01-01-2006, 10:17 PM
dragonwagon dragonwagon is offline
dragonwagon is starting off with a positive reputation.
Hey guys
Hey guys, whats goning on? I just registered on the site and I am a proud owner of a 93 black lightning. Just thought i would introduce myself to the community. I'm also interested in any ideas on how to improve my trucks horsepower. Any thoughts would be greatly appreciated.
Old 01-02-2006, 01:39 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Hi and welcome to FTE!
Old 01-02-2006, 05:15 AM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
http://www.ford-trucks.com/forums/showthread.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. .
Old 01-02-2006, 09:59 AM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Congrats!
Some good bolt-ons for a GEN 1 L are headers, exhaust, pulleys, CIA and advance the timing 2-3 degrees.
Old 01-02-2006, 01:58 PM
What it CIA
I am prety new at working under the hood. I know the basics of the engine but thats as far as my knowledge goes. What is CIA and how would I advance my timing? Would there be a realiabilty issue if I did?
Old 01-02-2006, 06:19 PM
Blurry94's Avatar
CIA=cold air induction. Essentially, you want to open up the inlet tract and Replacing the stock air box and filter, with an open element (cone type) filter is essentially the same.
Advancing the timing is easy: With the motor off, find the spout connector and remove the jumper. You can find the connector just under the cruise control servo on the passenger side fenderwall. Once you remove the jumper, you just set the timing like normal; loosent the distributor bolt, attach the timing light clamp to the #1 plug wire and start the truck. If the timing hasn't been messed with, then it should be set to 10 degrees BTDC on the harmonic balancer. Make sure it's warm when you do this.
If you need more/detailed info, then let me know.
Old 01-02-2006, 06:49 PM
e9tac's Avatar
e9tac e9tac is offline
e9tac is starting off with a positive reputation.
Matt, isn't the spout on the drivers side?
Old 01-02-2006, 09:33 PM
Blurry94's Avatar
Quote:
Yes, you are right...I don't know what I was thinking.
Old 01-04-2006, 08:54 PM
e9tac's Avatar
And I just so happen to be selling my CAI for $175 shipped.
http://www.ford-trucks.com/classifie...ct=7677&cat=10
Lap top computers 150ford Nebraska Chapter 11 02-11-2008 06:48 PM
Just another new guy. TRoper New Member Introductions 1 11-12-2007 02:07 PM
Y block t shirt stinkfist Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 11-08-2007 01:20 PM
Hey Guys bighibbi New Member Introductions 2 09-18-2007 11:35 PM
new to site jdiesel02 New Member Introductions 1 02-05-2007 06:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
