Governer on F600 Carb
The governor limits the RPM of the engine which in turn limits the maximum speed. I am not sure what the reason for it is; possibly to keep the driver from over-revving the engine between shifting or to keep the driver from exceeding the speed limit. Either way, it probably helps reduce operating costs in repair, gasoline, and accidents.
I doubt the governor would be adjusted to back off throttle much lower than 3000 RPM, so I don't believe it would be the cause of it dying at startup. I would check out the choke operation first, especially if the governor otherwise operates normally.
wcasey
11-04-2016 07:48 PM
