Had a Audiovox Keyless / Alarm installed about a year ago at a local shop and now the alarm works but the keyless does not. Anybody know about this type of issue and what it could be??? Or should I just pony up and have a new one installed.
If so they would have connected the green unlock wire to the pink with green stripe at your keyless module located on your firewall. Hit your lock switches and you should hear is clicking on the firewall.
Also some systems have fuses for the lock system on them and maybe that fuse is blown.
do the power locks work?
if yes, the relays they added are connected fine and the lock wire to the lock relay (or unlock whichever isn't working) is disconnected or the relay is bad.
A new relay is $5 at any part store.
They are just a plain Bosch relay.
Some alarms have built-in relays, some don't
You'll just have to inspect it.
If the alaem has a green and a blue wire (Lock and Unlock) they probably go to a pair of relays
audiovox would warranty the alarm if you have proof of purchase.
Sorry it tool so long to respond I have been crazy busy at work. When I set the alarm I hear a clicking (relays). So I guess I'll have too look for a disconected wire or something.
