PCM location on my 2001.
Old 01-01-2006, 07:19 PM
Clint40's Avatar
Clint40
Clint40 is offline
Hey guys want to verify where the PCm is on my 01 SC psd. I believe its near the emergency brake but want to make sure. I am hooking up a Bd X monitor and need to hook into the trans temp wire which is orange / black. This is my first time messing with the PCM so I just want to make sure where its located.
Old 01-01-2006, 07:28 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
That's where the PCM is but all of the wiring is in the engine compartment. The mult-wire connector is connected to the PCM through the firewall and is secured by a 10mm bolt. You sould be able to see it just under the brake master cylinder.
PSNut's Avatar
PSNut
PSNut is offline
YUP...next to parking brake...has silver gray metal cover slid into black mount frame.
Old 01-02-2006, 05:32 AM
Clint40's Avatar
Clint40
Clint40 is offline
Ok I see the PCM and wire harness which exits thru the firewall. In the instructions for the X Monitor it say use the number 37 postion, orange/black wire for the trans temp connection. Think I would be better off not messing with the PCM and just look thru the wires in the harness and tap into what I need and just leave the PCM alone??
sinapu
03-20-2017 06:01 PM
cwstanley
6.4L Power Stroke Diesel
05-01-2012 09:07 PM
bobsimrak
10-17-2011 01:42 PM
redman84
03-08-2011 11:28 AM
jtharvey
01-09-2006 07:15 PM
Quick Reply: PCM location on my 2001.
