PCM location on my 2001. - Ford Truck Enthusiasts Forums
Old 01-01-2006, 07:19 PM
Clint40's Avatar
Clint40 Clint40 is offline
Clint40 is starting off with a positive reputation.
Hey guys want to verify where the PCm is on my 01 SC psd. I believe its near the emergency brake but want to make sure. I am hooking up a Bd X monitor and need to hook into the trans temp wire which is orange / black. This is my first time messing with the PCM so I just want to make sure where its located.
Old 01-01-2006, 07:28 PM
guzzle92's Avatar
guzzle92 guzzle92 is offline
guzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to allguzzle92 is a name known to all
That's where the PCM is but all of the wiring is in the engine compartment. The mult-wire connector is connected to the PCM through the firewall and is secured by a 10mm bolt. You sould be able to see it just under the brake master cylinder.
PSNut's Avatar
PSNut PSNut is offline
PSNut is gaining momentum as a positive member of FTE.
Quote:
YUP...next to parking brake...has silver gray metal cover slid into black mount frame.
Old 01-02-2006, 05:32 AM
Clint40's Avatar
Ok I see the PCM and wire harness which exits thru the firewall. In the instructions for the X Monitor it say use the number 37 postion, orange/black wire for the trans temp connection. Think I would be better off not messing with the PCM and just look thru the wires in the harness and tap into what I need and just leave the PCM alone??
How to check the SPOUT connection for continuity sandymane 1987 - 1996 F150 & Larger F-Series Trucks 3 12-12-2016 01:31 PM
Pcm relay location Bigpipes 35 1999 to 2016 Super Duty 2 04-21-2013 06:39 PM
PCM '08 f350 6.4 location cwstanley 6.4L Power Stroke Diesel 2 05-01-2012 09:07 PM
How do i locate the pcm,95 f350 bobsimrak 1987 - 1996 F150 & Larger F-Series Trucks 12 10-17-2011 01:42 PM
PCM code redman84 1994.5 - 1997 7.3L Power Stroke Diesel 2 03-08-2011 11:28 AM
Tags
01, 2001, 2001ford, 250, 350, 73, 73l, control, f250, ford, located, location, module, pcm, powertrain, psd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
