429 horsepower rating - Ford Truck Enthusiasts Forums
Old 01-01-2006, 03:29 PM
351m_torque 351m_torque is offline
351m_torque is starting off with a positive reputation.
anyone have any idea on how much horspepower and torque a stock 1969 429 4 valve engine with ported and polished dove heads would make?
thanks in advance
Old 01-01-2006, 04:34 PM
fordsrgrt fordsrgrt is offline
fordsrgrt is gaining momentum as a positive member of FTE.fordsrgrt is gaining momentum as a positive member of FTE.
from the factory they were rated at 365hp ,but in reality im told they were probably closer to around 325.so depending on who did your headwork im guessing maybe 345-350 on a bone stock 429.now add a alumn intake headers ,cam and carb and then you could be around 425 or so
Old 01-01-2006, 04:59 PM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
Well a 429 4 barrel (4V stand for 4 venturi, the 429 has 16 valves) with ported & polished D0VE heads is hardly stock and the definition of "ported & polished" is pretty generic. The factory rating for the 69-70 429 ThunderJet with 11:1 compression and a 4V carb was 360. That was SAE gross HP which consisted of dynoing the engine with no accessories and a minimal exhaust system. Some say that it was over rated for advertising purposes although the 429 CJ was rated at 370 HP and the consensus seems to be that it was under rated for insurance purposes.
If and that's a big if, the head work was done correctly there could easily be an additional 30-40 HP depending on the exhaust configuration. If all they did was hog out the ports & gasket match then it's probably just a 429 block with a pair of iron paperweights bolted on top.
Old 01-01-2006, 05:26 PM
thanks a lot for the replies any idea on torque? curious because it is going into a 78 f-150
Old 01-01-2006, 06:16 PM
Bill_Beyer's Avatar
The factory rating for the 429 CJ was 370 HP @ 5400 RPM/450 TQ @ 3400 RPM. I have a stock 429 4V ThunderJet in my 1970 XL. It pushes that 3800 lb car around just fine even with the tall rear end gears. The only modifications to the engine are a Pertronix Ignitor ignition module and a BG Demon 725 CFM carb.
Old 01-01-2006, 09:21 PM
should this engine be enough to push my 78 f-150 around with still quite a bit of power? i have a 3.50 gear ratio with 33 inch tires
Old 01-01-2006, 09:56 PM
Bill_Beyer's Avatar
More than enough. My 400 moves my 79 F250 4X4 with 3.50 gears and 33" tires around very well. The 429 will have power to spare.
Old 01-02-2006, 11:34 PM
cmepasu cmepasu is offline
cmepasu is starting off with a positive reputation.
Quote:
Mine is not a 4X4 but the truck weighs in at 4160 lbs with me in it. No doubt you will be happy with a early 429/460 ( No Substitute for Torque in Cubic inches) check out my Gallery!!!!
Old 02-21-2006, 02:58 PM
77bigblock's Avatar
77bigblock 77bigblock is offline
77bigblock is starting off with a positive reputation.
I have a 460 with C9VE heads in my 77 F250. I occasionally put 6000 lbs of whatever needs to be hauled behind it and it does just fine. It will do whole lot more if I ask it too.
Old 03-19-2006, 09:04 PM
64Shortie 64Shortie is offline
64Shortie is starting off with a positive reputation.
429 C9ve-b
I'm new to this site and just recently bought a 64 f100 and also purchased a 429 w/ c6 tranny. Since I'm new to the ford world I was wondering if anyone knew what year/type engine I have, C9VE-B from what I can gather is a 69, but other than that I'm not sure.
Old 03-20-2006, 08:42 PM
77bigblock's Avatar
I believe that those are the 9.5:1 compression heads. I don't know specifics on the 429, but since I have a 460 with the same heads, I do know that they produce about 360 HP. You will have to run Premium with them too.
Old 03-20-2006, 10:52 PM
Bill_Beyer's Avatar
C9VE and D0VE heads are the same. They run 10.5-11:1 C.R.
best transmission for a 429 ryceman168 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 04-23-2014 02:39 PM
1988 F700 429 4v HP and TQ factory rating?? phoneman91 Large Truck 3 12-19-2009 12:03 AM
429 hp/torque ratings 006f350diesel Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 07-15-2006 02:02 AM
1976 FORD pickup 429 stock power rating? oldyeller 1973 - 1979 F-100 & Larger F-Series Trucks 16 02-02-2006 08:24 PM
I need the torque sequence for my 429/460 intake manifold 1972 Ford Thunderbird 429 V8 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-21-2002 07:04 PM
Tags
350, 429, 4v, bolt, cam, dove, engine, ford, gear, good, head, horsepower, hp, main, rating, ratings, thunderjet, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
