Suggestion for Tune-Up on 2000 F-150? - Ford Truck Enthusiasts Forums
Old 01-01-2006, 11:22 AM
Jm03 Jm03 is offline
Jm03 is starting off with a positive reputation.
I am new to the site and will be taking my 2000 Ford F-150 with the 5.4L in for Radiator Flush,Tranny fluid change,Fuel filter Change,and Air Filter.I have about 60,000 miles on it.I do this every two years regardless of mileage.
Is there anything else that should be done or checked.It runs really good outside of a little flapping sound when I first start up when its cold.
What about Spark Plugs & wires and serpentine belt????
Any advice is appreciated,Thanks!
Old 01-01-2006, 11:53 AM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum
Check the belt for signs of cracking on the ribbed side.
It doesn't have plug wires, it has a coil on each plug.
Plugs aren't due until 100,000 miles, but can be changed if you want too.
Maybe a new PCV valve wouldn't hurt.
Old 01-01-2006, 08:43 PM
ccoram ccoram is offline
ccoram is starting off with a positive reputation.
Wouldn't be a bad idea to check the differential fluid either and replace if dirty. Make sure they use 75w140 synthetic gear oil and possibly friction modifier though if it needs to be replaced. Not just standard gear oil.
Old 01-02-2006, 09:11 AM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud ofpreppypyro has much to be proud of
When I changed oils in my truck, I put 80/90 back in, just because that day I couldnt find any synthetic, and so far it seems good, although I am going to switch all oils to synthetics pretty soon. Been saying that for about 6 months now too haha
2000 f150 v6 ticking sound? drumrooster 1997 - 2003 F150 1 03-02-2016 11:07 AM
98 Ford F150 Problem.Maybe Coil packs?? James William Combs 1997 - 2003 F150 7 11-18-2013 09:19 AM
7.3 can't go over 30mph till i get amile down the road pipeman 1999 - 2003 7.3L Power Stroke Diesel 28 06-20-2012 12:30 PM
v10 stalls at 2000 rpms needinfo Modular V10 (6.8l) 18 05-28-2012 07:56 PM
2000 f150 factory propane wtroger 1997 - 2003 F150 11 06-15-2006 09:15 PM
Tags
150, 2000, 2006, 42l, 54, 8090, f150, ford, full, harley, involved, truck, tune, tuneup, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
