1995 F150 4wd - Ford Truck Enthusiasts Forums
1995 F150 4wd
Old 12-31-2005, 06:08 PM
pat2469 pat2469 is offline
pat2469 is starting off with a positive reputation.
1995 F150 4wd
I was just given a 1995 F150 4x4 with manual locking hubs and I do not know the proper way to put it into 4WD. Do I lock the hubs first and then put in 4wd? Do I need to be stopped and in neutral? Any assistance would be much appreciated. This site was a nice find. Will try and become a regular.
Old 12-31-2005, 06:59 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
..See you on the boards.
Old 12-31-2005, 07:14 PM
ramboss429's Avatar
ramboss429 ramboss429 is offline
ramboss429 is gaining momentum as a positive member of FTE.
Lock the hubs first, then put it in 4x4. You can slightly be moving when you engage the 4x4, it all depends on the truck, some you can be going under 45 and engage it. Best thing to do is put it in 4x4 when its not moving.
Old 01-01-2006, 04:50 AM
Oval_obsessed Oval_obsessed is offline
Oval_obsessed is starting off with a positive reputation.
If you want to shift into 4lo, you definitely have to be in neutral and stopped. Like ramboss said, you can be moving to shift into 4hi.
Old 01-01-2006, 04:56 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
4 lo it must be in N to engage or engage 4 hi when the speed is under 30 mph. hubs need to be locked before placing it in 4x4.
Tags
1995, 4wd, f150, hub, locking, manual
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
