NSS Pic Request (Crashed truck) - Ford Truck Enthusiasts Forums
Old 12-31-2005, 02:24 PM
satx77stepside's Avatar
satx77stepside satx77stepside is offline
satx77stepside is starting off with a positive reputation.
Exclamation NSS Pic Request (Crashed truck)
Does anyone have a good picture of the NSS (neutral safety switch) that mounts to the side of the C6 tranny?
I've got a '77 that was converted to a tilt column. Currently NSS is bypassed to allow starting in any gear and reverse lights are hooked up to a toggle. THIS SETUP HAS WORKED FINE FOR ME THE LAST 8 YEARS W/ NO PROBLEMS.
Story that might be funny in a couple of years but not right now:
Left truck at mechanics to get an inspection sticker. When I went back to get it I started it up to allow time for it to warm up while I paid (reached in and turned the key, didn't even get in). They left it parked in REVERSE(!!) -- needless to say I got a nice view from inside the shop of it (after warming up enough to get a nice idle going) taking off across the parking lot before SLAMMING into their GAS PUMPS(!!).
Now, even though I've gone 8+ years without a NSS I'd like one.
Before I buy one though I'd like to make sure my tranny has the mounts that would allow me to set it up. I've got the shop manual but that has a crappy illustration of the setup and I'm not sure I could tell just going by that.
Thanks in advance!!!
Old 12-31-2005, 03:27 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Old 12-31-2005, 05:24 PM
Mil1ion,
Thanks for the reply. I went out and took a picture to try and compare the linkage.
http://www.ford-trucks.com/user_gall...id=100356&.jpg
It looks like the blue linkage comes down to what is labeled "outer manual lever", however in the illustration that lever appears to go beyond the tranny oil pan while in my picture it's not even close. Also my pic has the extra lever with the green hole.
I know... I know... illustrations are simplified. I just want to make sure everything is A-OK before doing anything. If that pic IS of the correct location, are the holes at the 11 & 5 O'clock position the correct holes? Again, using the illustration they appear to be a LOT more tilted than the holes I'm looking to find.
Also (geez, what a mess), assuming that is the correct location and I have the proper mounting holes to mount this sucker do I also need to make sure the round spacer has the correct indentations to match the keys on the NSS shown?? (I know, I should just look/feel to see if they do, but so far I've managed to not get too dirty and I'd to keep it that way until next time I'm in my "working on my truck" clothes)
http://www.ford-trucks.com/user_gall...id=100360&.jpg
Didn't know if the tranny's that used the column mounted NSS still used the same "spacer/whatever" as those that mounted the NSS on the tranny.
THANK YOU SO MUCH FOR YOUR HELP!! (If you can answer all these new questions I'm definitely going to click on the scale icon to make sure you get those points for whatever they're good for! )
Old 12-31-2005, 06:03 PM
Mil1ion,
The blue lever is the kickdown rod
The green holed lever is the main shifter linkage
Those holes are correct
IIRC ,That plastic sleeve only fits one way., You need to put the shifter/trans in neutral, Set the NSS so the hole has a drill bit in it (Neutral position) and then slide it on to the shaft in place of the spacer.
Do you already have the NSS to install on the trans ?
Old 12-31-2005, 06:47 PM
Excellent.
Great information!
No, not yet. Are certain brands more prone to failure than others?
Thanks a ton for these replies, I really appreciate them!!
Old 12-31-2005, 06:51 PM
Ok, just a quick overview.
To add NSS.
Remove nut.
Remove kickdown linkage.
Remove plastic spacer.
Install NSS in place of spacer.
Line up NSS w/ drill bit.
Tighten down NSS.
Replace kickdown linkage.
Replace nut.
Is it really that easy? (besides the wiring of course )
Old 12-31-2005, 06:59 PM
The shaft with the nut on it should have an indent for the shifter arm as per the illustration in my frst reply.
There should also be a long linkage that runs from the NSS right to the shift arm on the bottom of the steering column
Old 12-31-2005, 07:14 PM
I'm sorry, you lost me on this one.
There's suppose to be linkage that attaches to the NSS from the steering column(??). I'm sure I'm just misunderstanding something.
Old 12-31-2005, 07:34 PM
Old 12-31-2005, 07:47 PM
Ok... I'm lost now.
Am I missing something on my tranny? It's been working fine the last 3+ years...
Old 01-01-2006, 12:28 AM
The NSS was Moved to the transmission in 1978 when Tilt columns (which doesn't affect this) were also introduced.
Therefore the linkages were different from previous years.
If you want a blown up pic of that linkage to the tranny just save my pic to your hard drive and use the zoom in feature in your picture program?
Old 01-01-2006, 11:29 AM
Ah, ok. So you're basically saying my linkage doesn't look like the NSS-on-tranny-pic because Ford used different linkage on the 73-77-NSS-on-column setup....
BUT YOU'RE NOT SAYING that I have to convert my linkage to the NSS-tranny linkage to put my NSS on the tranny (my current linkage will work fine, it just looks different), CORRECT?
Thanks!
Old 01-01-2006, 12:25 PM
You will need the linkage from the 78/79 to use that NSS
The important part is whether the shaft on the transmission you have will accept the 78-79 NSS & the shifter arm.
Old 01-01-2006, 12:33 PM
oh...
damn.
Do you know why this setup requires the other linkage? (Does the current linkage get in the way of the NSS?)
Old 01-01-2006, 12:35 PM
Do you know how to copy the image I posted ?
Tricking the NSS/Reverse Lights grinnergetter 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-08-2012 08:05 AM
Backup lights without a NSS? CalebJns 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-18-2012 10:25 PM
2001 escape xlt neutral safety switch/transmission range sensor DaveinRoswell Escape & Escape Hybrid 0 12-05-2010 10:47 PM
'79 c4 roosterst 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-24-2009 11:47 PM
nss wire diagram for a 1974 column mount awfulaggravated Electrical Systems/Wiring 14 06-10-2007 08:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
