1998 ford explorer 4.0 blown fuel pump fuse - Ford Truck Enthusiasts Forums
Old 12-30-2005, 11:43 AM
darrengj darrengj is offline
darrengj is starting off with a positive reputation.
The fuel pump fuse on the explorer keeps blowing when I try to start it. Where should I start looking?
Thanks,
Darren
Old 12-30-2005, 03:09 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
You can try replacing the fuel pump relay, but I'm not sure if a faulty relay would cause the fuse to blow. Normally, a faulty relay just results in the pump not running.
Old 12-30-2005, 03:32 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Heres how a 97 is wired, yours is probably the same: PDB fuse 3 to relay to inertia switch to fuel pump. Try opening the inertia switch & see if a new fuse blows.
Old 12-30-2005, 10:39 PM
thanks, i will test out the fuse with the inertia switch open and closed tomorrow.
Darren
Old 12-31-2005, 12:51 PM
Question
Quote:
I opened the inertia switch and put a new fuse in, then turned the key on. The fuse did not blow. I then closed the inertia switch and then turned the key on and the fuze immediately blew. I am assuming now that there is some kind of wiring problem after the inertia switch, or the fuel pump itself.
I do not have a manual for the Expy, does anyone have a wiring diagram for the fuel electronics?
Thanks,
Darren
Old 12-31-2005, 01:31 PM
The 97 EVTM shows from inertia switch to fuel pump is wired pink/black stripe.
Theres a connector that appears from the diagram to be under the drivers side floorboard.
If you open that connector & a new fuse does'nt blow, theres a short in the PK/BK between there & the pump or possibly the pump is locked up.
Have you tried giving the gas tank a good whack with your hand? Sometimes that will bring a bad pump back to life temporarily.
Old 12-31-2005, 01:46 PM
I will try opening the connector first. I will also try a whack on the tank.
Thanks,
Darren
Old 12-31-2005, 03:13 PM
how many wires go into the connector and how many come out? I found one that is grey, but I am not sure if it is the right one.
Darren
Old 12-31-2005, 08:03 PM
Just pink/black, try following the wire from the tank.
Old 01-01-2006, 01:34 PM
I found the connector. I disconnected it and turned the key and the new fuse did not blow. Now I am assuming that the pump is bad.
Darren
Old 01-01-2006, 02:55 PM
Is that connector under the dash or under the floorboard? The wiring diagram isnt clear on that. If it's under the dash, take a look at the wiring where it goes thru the sheet metal to the underside of the truck.
Also there is a connector at the tank with 6 wires that you can disconnect & see what it does.
Old 01-01-2006, 03:06 PM
I bought a haynes manual to find the connector. It is located right under the driver side door on the inside of the frame-rail. It has multiple wires going in and coming out of it.
Next I am dropping the tank and will disconnect the connection on the sending unit.
Darren
Old 01-01-2006, 09:48 PM
After looking at the wiring I found a bare power wire (the brown and pink wire). It was right before the connector that goes to the sending unit/fuel module. I repaired it and all seems to be working as it is supposed to.
Thanks for your help.
Darren
Old 01-02-2006, 01:42 AM
Good deal, glad to hear you got it fixed.
fuel pump not running Brenda Lamka Explorer, Sport Trac, Mountaineer & Aviator 20 12-16-2016 05:18 PM
EEC Fuse Burning Out irishman Explorer, Sport Trac, Mountaineer & Aviator 4 10-16-2014 10:36 PM
2003 Ford Explorer Washer Fluid Pump mweaver644 Explorer, Sport Trac, Mountaineer & Aviator 2 01-26-2014 12:20 AM
2004 Explorer XLT Cranks but wont turn over...HELP hurley1718 Explorer, Sport Trac, Mountaineer & Aviator 5 04-27-2011 12:21 AM
1995 Explorer starter solenoid fuse myblkexpy Explorer, Sport Trac, Mountaineer & Aviator 1 02-06-2011 10:02 AM
Tags
1998, 2002, 2006, 40, blowen, blowing, blown, explorer, ford, fuel, fuelpump, fule, fuse, identify, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
