Stuck wastegate on a 6.0 Garrett turbo - Ford Truck Enthusiasts Forums
Old 12-29-2005, 03:46 PM
Forddeiselman Forddeiselman is offline
Forddeiselman is starting off with a positive reputation.
Smile Stuck wastegate on a 6.0 Garrett turbo
Who was it that said that the 6.0 does not have a wastegate?
Mine has stuck several times and I had to replace it today at a cost of $399.00 just for the part.
It is mounted on the side of the Garrett turbo and dumps exhaust gases to regulate the turbo boost.
Since exhaust gasses pass through it, it sometimes gets plugged with carbon according to the dealer. I got tired of trying to clean it, so I replaced it today.
When it fails, the turbo won't build boost and the truck will fall flat on its face..
Result: No power. It will run at idle fine, but when you try to tromp it, nothing.
Forddieselman..
All replies welcome.
And howdy to ya'all
Old 12-29-2005, 03:50 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
http://www.ford-trucks.com/forums/sh...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. .
Moved and member notified
Old 12-29-2005, 04:41 PM
EnviroCon EnviroCon is offline
EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.EnviroCon has a good reputation on FTE.
Is there anyway you could post a part#. I'm no expert on these engines, but I know for fact that they do not have a wastegate. The VGT vanes control the amount of exhaust backpressure inside the turbo by opening or closing. So I'm curious as to what part you had replaced/problems with. It could be someone is using the wrong term for a part. The price and problems you gave sounds like you had the EGR valve replaced.
Old 12-29-2005, 05:13 PM
PSD6litre40's Avatar
PSD6litre40 PSD6litre40 is offline
PSD6litre40 is starting off with a positive reputation.
These engines DO NOT have a wastegate I gaurantee you that, a wastegate dumps on the compressor side of the turbo not the impeller side........
Old 12-29-2005, 05:22 PM
Quote:
Originally Posted by Forddeiselman
It has what is called ERTV. Something with electronically controlled turbo vanes. It also had the wastegate valve on it like I mentioned in my post. If you look at the turbo from the passenger side, it is right in the middle of the turbo between the exhaust and the intake wheels.
Forddieselman.
Based on that description, I think your referring to the VGT control valve. From what I understand this valve uses oil to operate the piston that controls the turbo's vanes. Either opening or closing them. So I guess in a very roundabout way it does the same job that a wastegate would do, but it's no waste gate. Unfortunately someone with actual experience working on these engines would have to tell you why it's being a problem.
Old 12-29-2005, 06:38 PM
CanadaGuy CanadaGuy is offline
CanadaGuy is gaining momentum as a positive member of FTE.
You are certainly describing the VGT actuator. If you've had to have yours replaced several times, perhaps you've got another problem... probably stuck or sticking vanes in the turbo. It doesn't function as a wastegate, what it does is open and close vanes in the turbo to change the size of the turbine housing to give you the best all around performance.
Old 01-14-2011, 11:04 PM
mph454 mph454 is offline
mph454 is starting off with a positive reputation.
Ford 6.0 turbo
Check out this website: www.powerstroke.com It has a gread clip explaining hoe the Garrett VGT turbo works!
Old 01-14-2011, 11:18 PM
Zmann's Avatar
Zmann Zmann is offline
Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.Zmann has a very good reputation on FTE.
link no worky
Old 01-15-2011, 12:00 AM
_Me2_'s Avatar
_Me2_ _Me2_ is offline
_Me2_ has a good reputation on FTE._Me2_ has a good reputation on FTE.
Quote:
Actually, a wastegate dumps from the exhaust side. A BOV or bypass valve dumps from the compressor side.
Old 01-15-2011, 12:32 AM
High Binder's Avatar
High Binder High Binder is offline
High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.High Binder has a very good reputation on FTE.
I'll sell you your next waste-gate for only $299.00
Old 01-15-2011, 07:19 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
As others have said, there is no wastegate. You are describing the VGT actuator. If your dealer is calling it a wastegate, then I would recommend you find another dealer...
Old 01-15-2011, 07:29 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Quote:
Has anyone noticed that this guy dug out a 5 year old thread with very old information???
Old 01-15-2011, 07:45 AM
Wow, I wouldn't have posted if I had noticed it was such an old thread.
Old 01-15-2011, 07:48 AM
Zmann's Avatar
Dang
I thought it smelled funny
Old 01-15-2011, 03:06 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
What a "waste". Should have closed the "gate" on this thread a few years ago!
Cheapest Garrett Turbo dealer is?? Streaky 6.0L Power Stroke Diesel 0 02-23-2015 05:26 AM
Keeping turbo wastegate when doing EBPV delete? xbox73 1999 - 2003 7.3L Power Stroke Diesel 10 05-05-2014 06:47 PM
Garrett Turbo Unison Ring Knuts 6.0L Power Stroke Diesel 6 03-01-2013 07:26 AM
Turbo Wastegate Frozen radjcw5 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-20-2011 12:21 PM
Need new turbo -- Garrett PowerMax? eman588G 6.0L Power Stroke Diesel 11 09-07-2011 07:56 PM
Tags
04, 06, 2003, 60, 60l, close, diesels, ford, gate, idle, open, powerstroke, turbo, waste, wastegate, wastegates
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
