how do dual gas tanks work? - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 12-29-2005, 02:16 PM
Brian_B's Avatar
Brian_B Brian_B is offline
Brian_B is gaining momentum as a positive member of FTE.
I ran a few searches, but kept getting hundreds of threads. The ones I read were about repairing or troubleshooting them.
I got this crazy idea of putting dual tanks on a truck. I know where to mount both tanks (I think) and which will fit in there (again-I think). More research and final measurements will be needed still. They will have the factory sending units and pumps in them (will be used).
I wanted to find out "how it works" before I go a lot further into research and locating parts.
How do the factory installed one work? My dad's 88 f-150 has a flip switch that goes from one tank to other (gas guage reads whichever tank you are on).
I am guessing both tanks feed into a control valve somewhere? The dash switch controls a relay that moves the valve and changes the electrical circuit to the guage?
Where are these things mounted typically? Anyone have a wiring diagram/fuel circuit diagram or know where I can find one?
Any help would be appreciated. I truly know less than nothing about these.
Thanks everyone,
Brian
Old 12-29-2005, 02:18 PM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
both tanks feed into a selector valve . you can flip the switch to select between tanks.
Old 12-29-2005, 02:21 PM
okst1 okst1 is offline
okst1 is starting off with a positive reputation.
If you don't want to screw with the electronics, you could use a valve like the one on my old Bronco. You manually rotate the valve to get gasoline from the tank you want to use.
Old 12-29-2005, 02:37 PM
Brian_B's Avatar
Thanks guys,
I still don't know how ford has it set up, but I did find a valve at jc whitney (would never use it) after you told me there was such a thing.
Here is the info: <TABLE cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD vAlign=top width=530>******** language=javascript src="/media/jcwhitney/jcw/javascript/backToCatalogRFX.js;pvad2581d3e2641e8d" type=text/javascript></SCRIPT>
POLLAK® MOTOR-DRIVEN FUEL TANK SELECTOR VALVE
<DL>For fuel-injected systems operating up to 65 psi. Designed to prevent returning fuel to incorrect tank. Weatherproof fiberglass-reinforced nylon valve body. Valve grounds to frame. Meets or exceeds DOT standards. Fits 3/8" I.D. fuel hose. Recommended fuse: 10 amps. Can be wired so original dash gauge indicates fuel level in either tank. Includes: switch, faceplate, wiring connector, instructions. Hoses not included—order separately. 6-port valve required on vehicles with 3 lines attached to fuel pump. For 12-volt systems. </DL><DL><TABLE class=appChart cellSpacing=0 cellPadding=0 width=409 border=0><TBODY><TR class=odd><TD class=tableCell align=middle width=42>Kit</TD><TD class=tableCell align=left width=26>ZX812705U</TD><TD class=tableCellPlain align=middle width=67>$53.99
</TD></TR></TBODY></TABLE>
</DL>
If I can find out more about the ford parts/wiring, I guess I will try to find one. My idea is not sounding so crazy now (to me anyway).
Okst1: I remember seeing one like that in an old ford when I was a kid. It seems like it was mounted under the edge (or end) of the seat? A lady ran our of gas on one tank and we almost never got it started again on the other. What memories!
As far as wiring...I hope to transplant a whole EFI system in. If I can do that (I hope I can), the valve will be easy.
Old 12-29-2005, 06:32 PM
Neb86's Avatar
Neb86 Neb86 is offline
Neb86 is starting off with a positive reputation.
My '86 (EFI) just relies on which in-tank fuel pump is running. The wiring is in the switch for the pumps and the senders. I don't seem to have a 'selector valve'.
Maybe I'm missing something?
Fuel Gauge Issue ljfordman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 08-16-2014 11:37 AM
Fuel gauge always pegged on full, both tanks racine 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-29-2013 05:05 PM
88 EFI econoline dual tank issue alvaroguillen 1968-2013 Full Size Vans 8 02-04-2010 10:25 PM
Fuel guage hack-around? axman_F250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 11-21-2009 12:13 PM
Dual gas tank switches and levers 66flareside 1961 - 1966 F-100 & Larger F-Series Trucks 7 04-01-2008 07:45 AM
Tags
body, dual, duel, explorer, f250, ford, fuel, gas, how, system, tank, tanks, trucks, valve, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
