What Would Cause a Turn Signal To Flash Quickly? - Ford Truck Enthusiasts Forums
Old 12-29-2005, 01:21 PM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Question What Would Cause a Turn Signal To Flash Quickly?
I just noticed in the last week and a half that both the left and right turn signal lights and associated dash indicaters blink really fast when activated. They used to blink maybe a couple times a second. Now they blink maybe 3 or 4 times a second. Does that indicate that the flasher can on the fuse block is nearing the end of it's life cycle? Nothing has changed on the truck. No new or special bulbs were installed.
Old 12-29-2005, 01:45 PM
76 F-150 390FE's Avatar
76 F-150 390FE 76 F-150 390FE is offline
76 F-150 390FE is starting off with a positive reputation.
its the flasher. my hazzard lights look almost like they are staying on they flash so fast, if i take tha flasher off my turn signals and put it on the hazzards they flash normal.
Old 12-29-2005, 01:49 PM
cigarxtc's Avatar
hmmm..Good idea. I haven't tried moving the hazard flasher for testing..sounds easy enough to fix. Guess I'll make a trek to the autoparts store for a new flasher. Hopefully it's only a couple buck fix.
Old 12-29-2005, 04:24 PM
77red4x4's Avatar
77red4x4 77red4x4 is offline
77red4x4 is starting off with a positive reputation.
I had a similar problem with mine except they would flash normal, then fast, cycling back and forth. I swapped the hazard and turn signal flashers and now they both work just fine.
Old 12-29-2005, 04:34 PM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
Some times when you have a bulb out it causes it to flash faster like that. So you know that its out. But is strange that both sides would do it at the same time. Just my 2 cents.
jason
77 f100
Old 12-29-2005, 04:39 PM
f-4x4's Avatar
f-4x4 f-4x4 is offline
f-4x4 is new and has a neutral reputation at this point.
i with the guy above me
Old 12-29-2005, 05:48 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Too much current draw will cause the quicker flashing.
That's why when you plug trailer lights (more draw) in on a vehicle with a standard flasher installed , one must replace it with a Heavy Duty Flasher. HD-12
Old 12-29-2005, 05:53 PM
Purdue Offroader's Avatar
Purdue Offroader Purdue Offroader is offline
Purdue Offroader is starting off with a positive reputation.
Too little current will cause it too. They put a circuit in the flasher so that you can tell if you have a burnt out turn signal. I had to modify the fenders on my 99 TJ and only used two of the 4 turn signal lamps, and this caused the quick flash, installing LEDs will cause it too. If this really starts to get to you look up TJ turn signals + LEDs and you should be able to find a link to site that will tell you how to fix the flasher. I'm sure that the flashers should be pretty much the same. But since you didn't do anything to your lights your best bet is to check and make sure all your turn signals work and nothing is messed up w/ your wiring.
Old 12-29-2005, 06:02 PM
With the Ford TS circuit, if a light filament is damaged, the lights WON'T Flash.The indicator light will just stay on...no blinking.
The GM circuit is the one that lets one bulb flash.
I can't see how a lower draw would cause the flash to increase.
Higher Current draw causes the seperation of the Flasher circuit sooner, That's why when you add Trailer lights the current draw is larger.... causing the bi-metal strip in the flasher to seperate quicker.
A HD flasher has a higher seperation rate than the light duty flasher thus blinks slower with the increased load..
Old 12-29-2005, 06:13 PM
77red4x4's Avatar
Quote:
Forgot to mention that all the bulbs worked, just flashed fast, then slow, then fast.....has worked fine ever since I swapped flashers.
Old 12-29-2005, 06:20 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Some HD flashers have a third pin for ground so they flash independent of the load.
Old 12-29-2005, 06:39 PM
sorry I didn't realize that ford had a different set-up though I should have. I was speaking from experience on my JEEP. There is a seperate circuit INSIDE the flasher that monitors the current draw. If it is not within the preset range (either high OR LOW) it will flash faster.
Old 12-30-2005, 10:44 AM
fasthauler's Avatar
fasthauler fasthauler is online now
fasthauler is gaining momentum as a positive member of FTE.
The bi-metal tab in the flasher heats up faster anytime the current increases. This causes the flaser speed to increase when hooking up a trailer. I am with dennis I'm not sure how a missing or burn't out bulb could cause the thing to speed up, but anything is possible.
As far as the LED conversion is concerned, the flasher will usually stop completely because the current is so low that the bi-metal tab cannot heat up. There is a solid state flasher that is available to cure this problem. They have been used on RV's for years and can be found in most RV supply houses.
Old 12-30-2005, 10:51 AM
trinogt's Avatar
trinogt trinogt is offline
trinogt is starting off with a positive reputation.
I once replaced the stock rear signals on my motorcycle with smaller lights. The flash was very fast. I needed a resistor in the circuit to get it back to normal flashing speed.
My truck is a Trailer Special, and uses heavy duty flasher relays, mounted under the hood near the ignition module. You can actually hear them click when they are on. Designed to handle a lot of extra light load.
Mark
Old 12-30-2005, 01:44 PM
its not done through a bimetal tab. Its done through a shunt resistor and internal comparator.......I don't know a whole lot about electronics so I only sorta understand but if you are really interested in it http://www.atmel.com/dyn/resources/p...ts/doc4727.pdf explains how this type of flasher works.....pin 7 in the lamp out detector. And tringot the resistor is one of the ways to fix the problem but its not usually prefered because the resistor can get really hot
**Update / Fixed**Turn Signal fast blink problem / 4 ways work normal dadriva 1999 to 2016 Super Duty 18 02-14-2017 10:21 AM
2000 Excursion, wont start, interior lights blinking mrvwbug Excursion - King of SUVs 11 07-29-2016 09:08 PM
Both turn signals blinking fast Fordhearter 1999 to 2016 Super Duty 12 03-24-2016 11:34 AM
Is it my turn signal flasher? *2fords* 1987 - 1996 F150 & Larger F-Series Trucks 3 08-22-2015 08:48 PM
SECURITY LIGHT WILL NOT STOP BLINKING Christopher Roche 2004 - 2008 F150 1 11-26-2013 06:14 PM
Tags
1978, bulbs, burn, f150, fast, flash, flasher, flashing, ford, lights, make, quickly, signal, signals, truck, turn, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
