ABS light
ABS light
I was driving on the interstate at 70-75 mph when suddenly a car in the lane next to me decided to switch into my lane.They were going no more then 30mph,when I suddenly slammed on my brakes.I then noticed the ABS light lit up on my cluster.It stayed on until I got to work.After I shut the engine off I restarted it and the light was off.Any thoughts as to what happened?Has this happened to anyone else? Should I be worried? Any replies are greatly appreciated.
You can probably retrieve a trouble code from the ABS that may lead you to what happened. If you have 4 wheel ABS you'll need a scan tool to get the code. If you just have rear wheel ABS you can get the code yourself. If you search here I think you'll find instructions for doing that.
If it was my truck I probably wouldn't worry about it unless it happens again. But it would be nice to know why it happened.
