92 Ranger w/2.3: poor start & no idle
on
1 Post
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 4 Cylinder Engine forum.
See ya on the boards!
-Matt
-Matt
I agree that it is most likely the idle air control valve. The best way to be sure is to "pull the codes". I recently had a similar problem with my 87 2.3. When I did the KOEO test it indicated a code 63. Emissions and diagnostics manual indicated a test to run if you get a code 63. Do test by shorting the TP and Ref Voltage connections at the TPS connector on engine side. Then run KOEO test again and see if you get a code 53. I did get a code 53. Manual indicated that positive on code 53 means bad TPS. Replace. I got one at Autozone ($42.00) and installed it. I then got a code 11 (No problems indicated) and the car cranks easy and runs great. No more idle problems cold or hot. Amazing!!
Clean your IAC and if that doesn't help, take it to Autozone for a free check of the engine codes.
VR666
13
06-16-2015 11:14 AM
bigdaddy coolbird
10-25-2014 10:17 AM
79aldean
05-21-2014 04:21 PM
