How not to get ripped off on Differential Work?
Hello,
I have to take my 99 F-150 XLT 2WD 4.6L I think its the 3.73 Limited Slip Diff (I know my wifes 04 is and I believe I bought the 99 in the same package) to get some work done on the differential tomorrow morning.
Here is why.....
I have taken great care of the Diff as I changed fluid three times in 80000 miles (it now has).
I had a leak in the front of the diff and had to have the front seal changed just over a year ago.
When the seal was changed I witnessed the guy have two other guys come over to look at it...... They made a change and then dropped the lift and test drove the truck. Something wasnt right and then he brought it back, lifted it, did something else to it and then said it was good.
11 months later, a slight noise could be heard but couldnt place where it was coming from exactly, pulled plug, fluid was good, and no metal.
A couple of months of light driving later, howl appears to now be coming from Diff. Had a guy drive it and listen to it and he said it is Pinion Bearings.
Dad said if crush ring is tightened too much, and not replaced, this would wear on pinion bearing and cause these problems. (Sounds like what happened).
Now this work out of warranty, looks like I am screwed for at least possible pinion bearings and axle seals, labor, and etc.
I cannot afford to have this work done right now without throwing it on the card, how can I prevent being taken for even more parts and labor at the dealer?
Any advice would be GREATLY appreciated!
Thanks,
Dave
Here is why.....
Thanks,
Dave
Thanks Ford390GasHog
Thanks,
Do I really need all of that? I heard they will likely try to sell me spider gears too eh? Yeah, they quoted me 900 if it only needs the bearings or something like that.
l/s unit rebuild, is that Limited Slip? In which case mine wouldnt need it...
Is there any hope that this will last if they do this stuff?
Thanks,
Dave
Thanks,
Dave
Originally Posted by ford390gashog
well plan on about 1500.00 at the dealer
they will want to do this
6 hours labor
axle seals
axle bearings
rebuild kit
oil
ring and pinion
l/s unit rebuild
they will also try to sell you brake rotors,pads,ebrakes,hoses non of that is needed.
6 hours labor
axle seals
axle bearings
rebuild kit
oil
ring and pinion
l/s unit rebuild
Try this link out for what it takes on a Diff setup
Shop labor should run a minimum of 5 hrs....8-10 is more realistic on a full rear end R&R. Shop labor in my neck of the woods is $70 or so an hour.
nvrsadi
05-17-2016 05:19 PM
navistardiesel
09-30-2014 08:46 PM
Kimberguy
12-14-2011 06:00 AM
98391, differashiol, differential, f150, ford, installation, labor, pinion, place, ring, rr, time, truck, work, works
