T18 Bellhousing Numbers
I have been searching all over the place for a T18 bellhousing that will fit a small block/300-6. I finally found one place that can get the bellhousing, but they need the numbers off of it to find it in their piles of junk. The bellhousing I have is for a 460 so I can't give them the numbers.
If anyone can give me the numbers off of it I will be greatly appreciative. I have searched all over for this bellhousing and came up completely empty. Without the bellhousing, I can't get my truck back together .
Yeah, I have read that the 400 and 429 bellhousings are the same. The 300 and small blocks are suppose to be the same as well.
The numbers are on top of the bellhousing, and if it is installed in a truck, I bet it would be pretty hard to see. I have taken a picture of my tranny to show you exactly where they are at.
Thanks for looking.
Thanks for looking.
I got this number off my bell-housing. It was on an 84 with a 302 and t-170 tranny.
E4TA 7505 - DA
This was stamped on the part of the bellhousing that mates with the tranny and you wouldn't be able to see it with the tranny installed (mine is on the floor at the moment). Hope this helps, not sure if it will........
E4TA 7505 - DA
you are correct. look in junkyards. i found one just two days ago for my 300/t19 project. found some more t19s that can be had for a decent price as well. they're installed in trucks, but they're there. you're looking for what's often referred to the small block or windsor bellhousing pattern. i'm up in northwestern montana. they're around, just gotta get dirty to find them sometimes in the older trucks.
if u dont mind me asking, where are you located?
i'll keep my eyes and ears open for ya man.
p.s. you wouldnt happen to have a spare shifter, would you? i'm looking for the shift lever, threaded collar, pin, spring...the whole assembly.
ok ill do some more searching in the yards. do you have any numbers on the one you found recently? might help some people out. also I'm in eastern NC. don't have any spares for the t19 laying around ill keep my eye open though. try manualtransmissionparts.com. they've got a big inventory if they don't have it they might no where to find it. thanks
knuckleharley
Flathead V8 & Flathead 6
01-05-2017 05:26 PM
Dave 64
06-18-2016 05:12 PM
MEvans043
06-20-2015 06:09 PM
pntrbl
11-14-2005 11:19 PM
