Offroad & 4x4
Radius Arms on a SAS
Old 12-27-2005, 05:23 PM
OffRoadF-150's Avatar
OffRoadF-150
OffRoadF-150 is offline
I have a 96 f-150 and i have begun to attempt an SAS. The axle i bought is off of a 78 F-150 and i also have bought 4 inch radius arm drop brackets from skyjacker. I am having trouble mounting the bracket. What all has to be done in order to mount this bracket and where is it mounted? Can i complete the SAS without installing the drop brackets (im doin a 4 inch lift)? If anyone has attempted an SAS and knows the solution to this problem, i would appreciate your input.
Thanks,
Will
Old 12-27-2005, 08:42 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
i hope you bought the lift for the 78 F150 b/c that is the suspension you'll be working on. what you need to do is get the axle bolted in and centered and the figure where your radius arm drop mounts go. now you dont have to use the radius arm drop mounts if you are just going with a 4" lift. all you have to do is order degreed radius arm bushings and that will tilt the radius arm up and point towards the stock nracket instead of having a bracket hang down and asking for a rock or stump to catch it (although never had a problem with that)
-cutts-
Old 12-28-2005, 04:27 AM
kev150's Avatar
kev150
kev150 is offline
im assuming that you got 4 inch coils to go with and a dropped pitman arm? And you know that your stock steering wont bolt up.
I recently did a sas on my truck, if you have any questions feel free to ask
Old 12-28-2005, 04:45 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
i hope you got the kit for the 78, you stock steering won't work worth a damn either.
Old 12-29-2005, 01:44 PM
Blueoval_boy_64's Avatar
Blueoval_boy_64
Blueoval_boy_64 is offline
I also got a 4 inch drop bracket for my sas, but I'm running 9 inch coils. I found that the frame on the doner rig was strait, and on my 94 was angled up, so I ditched the brackets and fabbed one up on my own. I have seen a sas done on a 80's with it just bolted to the frame, and I didn't like the angle that the radius arm was going threw the bracket. Hopefully I'll have pics on here soon of my sas.
Old 12-29-2005, 03:48 PM
kev150's Avatar
kev150
kev150 is offline
I've got a set of radius arms with extentions from Bent and twisted offroad if you are interested
Old 12-29-2005, 03:57 PM
78f3504x4's Avatar
78f3504x4
78f3504x4 is offline
I did the same sas setup 4 years ago on my old '94. I used the 78 radius arms and 78 brackets, 4" coils for a 78, and 4 degree c-bushings. If you try to use the '96 brackets, you will be spending a lot of time under the truck swearing. I have swap pics in my gallery. In my gallery I have a pic that shows exactly where I mounted my radius arms.
9.ford.5
Offroad & 4x4
144
01-15-2022 07:25 AM
jdmullins29
Offroad & 4x4
08-22-2015 08:22 PM
fordf350man
1978 - 1996 Big Bronco
08-07-2015 08:03 PM
Sparky96
03-20-2015 08:04 AM
TallGuy_Az
Offroad & 4x4
07-01-2005 10:39 AM
Quick Reply: Radius Arms on a SAS
