how much horsepower a 351m/400 block can handle
Assuming a good rebuild with quality parts including forged pistons and a reasonable boost pressure you should be able to easily run up to 500 HP as long as you put some sort of rev limiter in it to keep under 6000 RPM. I would definitely make sure to keep the static C.R. around 7.5:1 to avoid detonation issues. 351M/400 heads aren't known for their great resistance to pinging/detonation.
i think it was 799/863 and about 16,000usd
and streetable if the lights are what 1/4 mile away and a long cooldown wait bween lights sounds fun but not real effective
but anyway isn't the wall thinnest at the bottom and furthur could you fill an inch or two up providing you can keep it 'level'
blueeyedfordguy
General Diesel Discussion
12-16-2013 02:22 PM
17witha664x4
02-29-2012 04:04 PM
Joe mollnow
34
03-15-2005 11:01 PM
