how much horsepower a 351m/400 block can handle - Ford Truck Enthusiasts Forums
Old 12-26-2005, 07:48 PM
old75F-100 old75F-100 is offline
old75F-100 is starting off with a positive reputation.
i was thinking if i turbo this engine what would be the hp limit before the stock rods break and the block cracks and wut about the crank if i was going to do this work i would do a rebuild with Arp bolts and copper head gaskets
Old 12-26-2005, 07:54 PM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
With a stock engine just turbo charged, something would go wrong. If you did a complete rebuild and turboed it, it should hold up fine.
Old 12-26-2005, 09:24 PM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
Assuming a good rebuild with quality parts including forged pistons and a reasonable boost pressure you should be able to easily run up to 500 HP as long as you put some sort of rev limiter in it to keep under 6000 RPM. I would definitely make sure to keep the static C.R. around 7.5:1 to avoid detonation issues. 351M/400 heads aren't known for their great resistance to pinging/detonation.
Old 12-27-2005, 03:41 AM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
I think ShaZam had around 700 horses with his... I think thats his username.
Mine makes around 385... no problems with it.
Old 12-27-2005, 03:46 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
i think 650 is about the limit. just have the block checked ofr cracks and make sure to have the engine balanced.
Old 12-27-2005, 10:14 AM
Bill_Beyer's Avatar
ShaZam did some other mods to his pulling 400 like putting filler in the block that you probably wouldn't want to do with a street engine.
Old 12-27-2005, 08:47 PM
battered_bronco battered_bronco is offline
battered_bronco is starting off with a positive reputation.
i think it was 799/863 and about 16,000usd
and streetable if the lights are what 1/4 mile away and a long cooldown wait bween lights sounds fun but not real effective
but anyway isn't the wall thinnest at the bottom and furthur could you fill an inch or two up providing you can keep it 'level'
D8VE BLOCK INFO baddad457 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 03-06-2015 10:01 PM
Stacking blocks Rudiak 1999 to 2016 Super Duty 4 06-27-2014 03:25 PM
Help with after market Engine block heaters please blueeyedfordguy General Diesel Discussion 9 12-16-2013 02:22 PM
352, 360, 390 block differences? 17witha664x4 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 02-29-2012 04:04 PM
Y block to fmx auto transmission Joe mollnow 1948 - 1956 F1, F100 & Larger F-Series Trucks 34 03-15-2005 11:01 PM
Tags
351, 351m, 351m400, block, boost, ford, handle, hold, horsepower, hp, limit, max, modified, stock, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
