Hello all FTE people, been a while since I last visited and I guess I am lucky because my 1993 F150 extra cab XLT 2wd has been good to me until recently.
The truck is a at a trans shop right now getting a rebuild. Something let loose in the case and was making a growling squealing noise. That's a different story.
The trans guys were nice enough to tell me that my cat convertor is sounding as if something is loose inside of it and I had been suspecting it was shot.
Truck has 100,400 on the odo. Since I and thinking that I would replace the cat and then do a full exhaust on it.
Here is what I came up with for a cat from Summit
| | CTO-9302
$179.99
Estimated Ship Date: Today
| Brand: | Catco | | Product Line: | Catco Direct Fit Catalytic Converters | | Inlet Quantity: | Dual | | Converter Inlet Attachment: | Stock flange | | Outlet Quantity: | Single | | Outlet Diameter (in): | 2 1/4 | | Converter Outlet Attachment: | Slip fit | | AIR Tube: | Yes | | Converter Case Material: | Stainless steel | | Converter Substrate Material: | Ceramic honeycomb | | Heat Shield: | No | | Converter Overall Length (in): | 58 1/2 | | Quantity: | Sold individually. | Catalytic Converter, Stainless Steel, Ford, F-150/F-250, Each Emissions-legal performance for your car.
| Then for the cat back
SUM-684011
$169.95
| Brand: | Summit | | Product Line: | Summit Cat-Back Exhaust Systems | | Exit Quantity: | Dual | | Exit Location: | Split rear | | System Material: | Steel | | System Finish: | Aluminized | | System Style: | Cat-back | | Muffler Included: | Yes | | Inlet Quantity: | Single | | Intermediate Pipe Diameter (in): | 3.000 | | Tailpipe Diameter (in): | 2.250 | | Tip Diameter (in): | 2.250 | | Quantity: | Sold as a kit. |
Exhaust System, Cat-Back, Dual Split Rear Exit, Aluminized Steel, Ford, F-150/F-250 Truck, Kit
That all comes to about $350. I got a compressor and a ton of shop tools. I've put on exhaust myself before, so this doesn't scare me. I would like to know an opinions if anyone has any? I can't spend a lot with the trans rebuild, but I need to get this stuff done too. I understand it is not stainless steel parts and it won't last forever.
