fuel leak with ats chip installed
Anybody experience fuel leak, after installing ts chip? Just installed it, used 3rd posioition onlly on flip chip, and had large leak around fuel pressure regulator. If this has happened to anyone out there, please let me know what needs to fixed. Thanks, Jeff
leaking green oring
The green oring you are talking about is located pm the threaded bolt which goes into the fpr right? I don't believe its leaking there but tell me about the cheaper fix, so I can save a few bucks if it actually is the problem. I sprayed some gunk in the area hoping to find the source of the problem. Whatever the problem is I know I didn't have any fuel leaks before I installed the chip. I know the chip raises fuel pressure, which could have led to the leaking fuel. No coincadence, you change pressure and things break or leak. Jeff
Originally Posted by 1997F-350
my ts didnt make my truck leak...
if it is the green oring from fuel bowl to fpr where the screen is leaking... let me know.. i have a great fix...much cheaper than the $50 dollar oring kit ford sells for the fpr.
A chip wont raise fuel pressure. It can raise the Injection pressure, but that deals with the high pressure oil pump. The only way to raise the fuel pressure is to shim the regulator.
Their is nothing electrical about the fuel system mech. pump, regulator. The only place the computer controls the fuel is at the injector.
