99 Exployer...Radio lights and rear wiper not working?
Old 12-24-2005, 03:57 PM
WildCountryEX's Avatar
WildCountryEX
WildCountryEX is offline
I have a 99 Eddie Bauer Expolyer and the radio lights (lights for the clock, radio station on the face plate) and the rear wiper dont work. They will come on if your on a rough gravel road, so I figure its a lose wire or something.
Thanks for any help!!
Old 12-25-2005, 01:52 PM
oshoguno's Avatar
oshoguno
oshoguno is offline
it's bad solder joints on the radio power supply. A very common problem. Your best bet is to do a search of the forum for blank radio display. Previous posts have detailed how to fix it or how/where to get it fixed.
As for your rear wiper there are many things that can cause this but I believe it may be a bad wiper motor ground. Again, doing a search of the forum would help you out.
Old 12-25-2005, 03:15 PM
CanadaGuy's Avatar
CanadaGuy
CanadaGuy is offline
On a '99,I'd be leaning toward a bad wiper motor. Give the arm a wiggle with the switch in the on position, and see if it starts to work. With the radio, I tried to fix mine a number of times with fixes posted all over the net, and then chose to send it to an electronics shop to fix it... best $30 I ever spent!
Old 12-26-2005, 11:14 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
coreyb
1997 - 2003 F150
04-08-2024 09:39 PM
don9235
2004 - 2008 F150
07-15-2011 01:22 PM
wiznewski
12-14-2004 08:27 PM
Chris Nikirk
Electrical Systems/Wiring
19
09-04-2004 01:15 PM
Quick Reply: 99 Exployer...Radio lights and rear wiper not working?
