91 A4LD front pump seal took a dump - Ford Truck Enthusiasts Forums
Old 12-24-2005, 09:41 AM
Dialtone Dialtone is offline
Dialtone is gaining momentum as a positive member of FTE.
Hey all
Got a question tor the tranny experts. During a 250 mile drive home last night, the front pump seal on my tranny let loose and dropped about a quart of ATF then stopped leaking for a while. Managed to get the beast home (another 100 miles or so) with no problems. Thing shifts just fine in all gears, converter lock-up works OK, no slipping or other problems.
The trans is about 2 1/2 years (25 K miles) since total overhaul and new-process converter, fluid and filter changed about a year ago. Fluid color is a bit off, but not burnt so much as I can tell.
Any suggestions as to how I should proceed? Should I drop the tranny and replace the seal or was this just "one of those things that happens for no apparent reason"? It does not appear to be leaking any more (but hard to tell with oil everywhere under there).
Dialtone
Old 12-24-2005, 11:56 AM
Jharger Jharger is offline
Jharger is starting off with a positive reputation.
Rest assured, everything in life happens for a reason. I recall a few posts about the front seals on these. Something about the fit of a machined boss being off. Try a search, I'm sure you'll find something.
Old 12-26-2005, 10:13 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
if the seal is blown out you will need a new front bushing in the pump and poss.a converter
Spray-On Bed liners: Rhino vs Speedliner Dialtone Aftermarket Products 51 10-01-2015 04:03 PM
Transmission leak jayjjcc Excursion - King of SUVs 12 04-30-2015 04:22 PM
2000 F250 7.3 4x4 Automatic. Reverse only. Mr.Lucky 1999 - 2003 7.3L Power Stroke Diesel 1 02-24-2015 07:20 PM
Leaking C6 tranny David LaPell Clutch, Transmission, Differential, Axle & Transfer Case 1 04-02-2014 04:50 AM
Leaky C6 tranny in my 73 F-100 David LaPell 1973 - 1979 F-100 & Larger F-Series Trucks 2 04-02-2014 12:19 AM
Tags
2002, a4ld, bushing, change, dump, explorer, f150, fluid, ford, front, leak, oil, pump, seal, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
