became a member of the HPOP O-ring failure club yesterday
well it happened one of the O rings on my HPOP failed. i was lucky because it was the one on the plug and not the feed lines. it was a very easy repair so dont worry if it happens to you, however if it was the feed lines that where leaking you would have to buy a $60.00 tool (number 6 quick release tool from SPX corp. model # ZTSE4449) to dissconnect the feed lines to replace the O-rings. the o ring kit was $35.00 ($31.79 plus tax) from ford (kind of steep if you ask me) and comes with all three o-rings, some #680 loctite and a pretty good set of instructions. blackcloud diesel sells the O-ring kit for $25.00 but i needed it today so i had to get it from the dealer.
i read that you may be able to get a quick realease tool for cheaper at a speed shop or automotive tool place but the only one i could find on the net was $60.00 and was from the company that the instructions say to get it from (SPX corp.). hope maybe this will help someone down the road.
to fix...yes dear u go and fix it because we need our truck to pull the camper,
i trust u completely...
The end of the hose that slips down into the fitting in the head, has a sleeve over a smooth tube (sticking out of the hose) that has a sliding collar on it with a bulge in the center. When you push down on the collar with the tool (towards the fitting) it moves the bulge down into a recess in the corresponding fitting, which allows the smooth tube to slide right up and out of the fitting. Hard to explain but if you could see it you'd understand. Its hard to imagine these can hold well over 3800 psi all the while swiveling around, and no using no o-rings.
Originally Posted by strokin_it7.3
Couldn't tell ya, AC is something i've never ventured into. Its basically what ford calls an STC (Snap-To-Connect) fitting. Slide down the collar towards the fitting, pull the hose and it comes out. Maybe researching could yield something.
Thanks everyone for the help. Once I knew what the fittings were called....
I found this instruction:
To release line from fitting:
While firmly pushing the line straight into the fitting with one hand, insert the tool behind the black release sleeve and gently pull on the line.
To connect lines to fittings:
Push the lines into the fittings until you hear/feel the snap ring "grab" the line. Insure connection by pulling on the line.
Note: Whenever high pressure system is opened, air enters the system and the vehicle needs to be driven to remove the air.
