TPS Adjustment?
FIPL is the large item on the drivers side of the IP with 3 wires.....
A/T - E40D FIPL Sensor Trouble Shooting & Adjustment
TECHNICAL BULLETIN # 186A
TRANSMISSION: E4OD
SUBJECT: FIPL troubleshooting & adjustment procedures
APPLICATION: Ford
DATE: Jan 1994
E4OD
FIPL Trouble Shooting & Adjustment Procedures (Diesel Applications Only)
Poor transmission performance and/or premature transmission failure may be caused by a defective Fuel Injection Pump Lever (FIPL) sensor, or sensor signal. The sensor is located on the Fuel Injection Pump (Figure 1) and is used to inform the Transmission Control Unit Assembly (computer) of throttle position.
Ford Motor Company recommends that the FIPL be checked or replaced every 50,000 miles. However, it is possible for a FIPL sensor to fail at less than 50,000 miles. Therefore, it is highly recommended that you install a new "upgraded" FIPL sensor when a transmission overhaul is performed on any diesel applications.
You should also be aware that early design FIPL sensors are not as desirable as late design sensors.
Another potential concern is that the wiring harness leading to the FIPL sensor may be broken or shorted to ground. Closely inspect the harness where it is routed across the top of the engine to the FIPL sensor. The natural vibration of a diesel engine can easily wear through the wiring insulation where it contacts the engine, brackets, etc.
Note The voltage specification for signal return (item 2, page 2) was incorrect on the original bulletin. Remove original # 186 from your files and replace it with this revised bulletin. # 186A.
Note For testing and adjustment information see following information.
TESTING THE FIPL SENSOR
Note During these tests the negative lead of the voltmeter MUST be connected directly to the negative battery post and the computer and FIPL harnesses must not be disconnected.
1. Wire A is reference voltage sent to the sensor from the computer ORANGE/WHITE
TEST: With the KEY ON, ENGINE OFF voltage should be approximately 5 volts.
2. Wire B is the ground path from the FIPL sensor to the computer BLACK/WHITE
TEST: With the KEY ON, ENGINE OFF voltage should be volts?? or less.
3. Wire C is the throttle opening signal sent to the computer from the FIPL sensor . TEST With the KEY ON, ENGINE OFF and the throttle at idle position, voltage should be approximately 1.2 volts. With The throttle fully open, voltage should be approximately 4.5 volts. ORANGE/WHITE (CENTER WIRE)
The sweep from 1.2 volts at idle to approximately 4.5 volts at full throttle should be smooth. A meter with a snapshot or min/max capture mode is useful to catch intermittent "opens".
If the previously described range cannot be attained, FIPL adjustment can be achieved by rotating the sensor (on its bracket) one way or the other until the voltage values are satisfactory.
DIESEL FIPL SENSOR INFO
DATE 1992
REASON
Early Black FIPL has High Failure Rate
RECOMMENDATION
Always replace the black colored early FIPL or any colored FIPL having 60 thousand or more miles with the late gray colored FIPL.
PART NUMBER
F2TZ-9B989-C
TRANSMISSION: E4OD
APPLICATION: Ford
DATE: Jan 1994
E4OD
DATE 1992
REASON
RECOMMENDATION
PART NUMBER
F2TZ-9B989-C
tps/fipl
I have a 1994 F250 4x4 SC long box E4od.I have a down shifting problem when feathering the throttle,it doesn't happen all the time and get's worse in the warmer weather.Even going down hill or flat road,Tranny guys in the Durham Region say there is no problem.It is fine under hard acceleration.Is this a condition you are having with the tps /fipl?I have 250000 km original transmission,injector pump and injector's done June 2011.
https://www.ford-trucks.com/forums/1...ions-only.html
Here ya be....there might be something in this article for you. Its all about the TPS...
on
however don't be confused with the converter unlocking/re locking.the E40D will enter a semi neutral state when coasting downhill to conserve fuel and is normal operation.
on
she feels like a semi neutral state when you let off the skinny completely while going downhill to conserve fuel.
next time you let off going downhill,at say 55mph,watch the rpms.slide her into N to see if they drop even further.if so,all is normal.
if she really is going into N on her own,that would (most likely) be a failed MLPS.
sorry i think i misunderstood the first time.hope i didn't cost ya a new MLPS friend.if so,hopefully you made sure the updated version that time,and in which case,it was good preventive maintenance anyway.
My truck didn't seem to slip into neutral it literally down shift's to 3rd and sometimes tried to go into 2nd,my rev's go up.The transmission feel's stronger already,I took it to work the day I picked it up and it took all the hills way better than before.It was a 100 km trip back and forth to work that day and had it out today and all is good.It's quite cool here now I'll see what happen's when the temp's go up.
Thank's for your interest.
on
them little suckers are so important to how this trans operates,it's just a good idea to plan on replacing them every 50k miles max even if you don't think you need one lol.
Golden Helmet
05-15-2015 07:48 PM
