Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-23-2005, 09:29 AM
badgtho is starting off with a positive reputation.
High Boy Power Steering - Valve Question!!
Hey guys... i havent posted in a long while but here goes the question:
i have a 73 250 highboy.. the truck has had a bendix style power assist put on it. the control valve leaks out of the stud where the pitman arm attaches (or seems to) i want to rebuild the thing but can;t find a kit anywhere. i can find a new valve for 250 bucks, but other than the one leak mine is fine. any suggestions?????
the next question is the pump is brand new. ever since day 1 it has whined liek an old beat pump. its been bled.. any thoughts?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 12-23-2005, 02:49 PM
robtinalimon is starting off with a positive reputation.
Maybe the first thing is to spray some degreaser on it, then wash. The leak may be from the threaded ends. Look for cracks somewhere. Dennis Carpenter has a rebuild for the ball stud kit, that may solve your problem, it is found on page 13 of their catalog. The whining from your pump is because of loss of fluid. You need to check the fluid with the engine warm and running. Turn the wheel left to right and back, to release any air. If your pump still whines then you need to replece it. Excessive heat caused by low fluid ruins the bearings.
  #3 (permalink)
Old 12-23-2005, 02:57 PM
thats so much for the reply. I bought the truck with the "new" pump installed.. wouldn;t surprise me if he didn;t have it quite full and that may have messed the bearings... it definitely pumps, so the noise i can deal with. its certainly full now. it is leaking from the ball-stud boot area... not from the 4 lines where they screw in.. i solved that part of it.
where do i get a dennis carpenter catalog? this is my 6th 73-79, the only one i've ever had with power assist.. i only ever get LMC.. so i am new to this world.
  #4 (permalink)
Old 12-23-2005, 03:13 PM
Ok so i answered half of my own question. i found them online,,, sure enough, thats it on page 13. so how hard is this to do? what is the advantage to a whole rebuilt unit?
if you have some more knowledge on this i'll be much appreciative.
  #5 (permalink)
Old 12-23-2005, 03:51 PM
I have not had the luck of rebuilding, the valve, yet. I had to replce the whole thing, because of a worn unit. It cost me 200.00. If you have the time and your wife has the patience, you could get it done.
  #6 (permalink)
Old 12-23-2005, 03:57 PM
Is it leaking at the 3 bolt area, where the two pieces meet?
  #7 (permalink)
Old 12-23-2005, 05:09 PM
hard to tell
its hard to tell... the drip is coming from the boot wheer the ball stud comes out of. i think its likely from in there, but could be both.
any experience with that?
  #8 (permalink)
Old 12-23-2005, 06:58 PM
No, maybe that rebuild kit will help....
  #9 (permalink)
Old 12-24-2005, 08:52 PM
30over is starting off with a positive reputation.
I would do the newer 78 79 F250 4x4 power steering conversion and never look back. You'll be glad you did.
__________________
1977 F250 Higboy 460 / C6
Lot of other goodies
Glad to be able to drive it again!!
  #10 (permalink)
Old 12-24-2005, 09:41 PM
Yes, but the best uses for the power assist is for large tire, whether you have them now or in the future. I run 33's on my truck and I would like to go to 36's. More meat is more turning resistance. With a good hydraulic assist steering you can turn those meats with one finger. I like it and just like my truck not many have (stock power assist)them. There is a new setup called the "Redneck Ram". Anywho, we all have are feticious...
  #11 (permalink)
Old 12-26-2005, 04:59 PM
the truck is in very good original type condition.. i dont really want to go to the newer style.. and retain the drum brake axle.. i'd get a 60 frn and then go all the way to converting it. i guess for now i'll look into that kit. thanks for the help guys. do you think its worth trying lucas in there? do you guys run ATF in you power assist>
  #12 (permalink)
Old 12-26-2005, 05:43 PM
ATF, works fine. Just keep in full.
  #13 (permalink)
Old 12-26-2005, 06:16 PM
koja one is starting off with a positive reputation.
I use a 2wd gear sector on these.I have not done one in about 10 years but it,s cheap and easy if you can weld.I' ve done it on 1/2 tons too.basically you make a plate with three nuts welded on it in bolt pattern of the sector. weld the plate on the inside of frame with nuts to the inside.You have to flatten your old pitman arm by v notchin it and reweldin it.If that bothers ya you can buy em that way.the pit man arm goes between the frame and the spring.these are easy ,it will steer like butter and 2wd sector are easy to get.f 150s are harder cause you have to notch the front crossmember but it can be done.This was a common cure 20 years ago.most shops had detail instructions.I stil got one. If you want I'll copy it and send it to ya.Its got a lota detail.two pages,I'll have to go dig it out.Is there a way to put on here like it is ?I think it's got some drawings.I'm not too computerized.
  #14 (permalink)
Old 12-26-2005, 06:44 PM
that would be great... you can scan it
  #15 (permalink)
Old 12-26-2005, 11:53 PM
no scanner,It's six pages.I'd gladly mail it or fax it.faxing it might fade the pictures.this has been copied a bunch.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
