P0156 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
P0156
Old 12-22-2005, 10:40 PM
Nappers Nappers is offline
Nappers is starting off with a positive reputation.
P0156
Hey guys,
I have a 2000 Eddie Bauer Expidition with the 5.4. I ran my code reader and it popped up a P0156 code, meaning O2 sensor (bank 2 sensor 2). I am unsure which O2 sensor that is. How many O2 sensors on this beast (tried to decipher info on a search but with dial up it sucks) and would it be better to replace all of them? It has 75,000+ on it.
The gas mileage did drop about 4mpg and not running as smooth.
Thanks in advance.
Aaron
Nappers
Old 12-23-2005, 09:46 AM
FTE Herman's Avatar
FTE Herman FTE Herman is offline
FTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputationFTE Herman has a superb reputation
It is the one after the cat on the drivers side. There are 4 HO2S (Heated oxygen sensors) on your vehicle. Two that are in the exhaust stream before the cats, which are used to monitor the air/fuel ratio and two that are after each cat, which measure their effectiveness.
Old 12-23-2005, 09:59 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The P0156 won't cause poor gas mileage, (HO2S2 is not used for fuel control) but the code can result from other conditions that do cause poor fuel economy.
If you have a misfire, address it first. It can cause excess fuel to be collected in the cat and keep the downstream O2 sensor from switching.
Other possible causes of a P0156:
An exhaust leak before the downstream sensor
Fault in wiring harness
Faulty sensor
Faulty PCM
Check your emissions warranty, some of these components are covered by your Federal warranty which, depending on where you live, could be an 8/80.
Replacing all four sensors would be a waste of money.
Steve
Old 12-23-2005, 10:14 AM
Thanks guys, I can see the O2 sensor through the wheel well, may see if a wire broke, didn't hear an exhaust leak but will check it out. It's got 75,000+ miles on it and may replace and reset light and see what happens.
Thanks again.
Aaron
Nappers
Won't pass smog, p0156 error code... Janice44 Exhaust Systems 2 03-30-2016 01:42 PM
1989 Ranger Nappers Ranger & B-Series 4 08-16-2015 11:49 AM
P0156 & P0161 O2 Sensor bluestang65 1997-2006 Expedition & Navigator 1 06-28-2010 08:48 PM
98 expedition p0156 code jima 1997-2006 Expedition & Navigator 3 12-14-2008 02:54 PM
Both O2 sensors out at same time? davisenvy 1997-2006 Expedition & Navigator 6 12-10-2008 09:54 AM
Tags
2000, 2004, 97, code, emissions, expedition, f150, ford, misfire, oxygen, p0156, pcm, sensor, truck, wats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
