Running Sirius wires to positive battery cable and ground.
Thanks to Matt for his advice on the Sirius antenna. Now my question is, where is their an access hole in the firewall to run wires to the battery? I mounted my Sirius tuner in the little cubby hole inside the glove box and to the right. I think the wires are just long enough to reach the battery if i can run a straight line, but i can't find a place on the firewall. I looked under the carpet on the front passanger side near the fuel reset and rubber mat that covers the firewall but couldn't locate a hole. Any advice. My truck is a 1999 F-150 super cab.Thanks to all.
According to my Sirius satellite tuner instuction book, it says to run one wire to the positive cable and one to ground from the tuner, then the head unit itself could be wired either as switched or constant{constant to maintain clock setting} and the Sirius tuner had to go directly to the battery to complete the circuit. I read that wiring the radio as a constant source was a drain on the battery, but if it is minimal, then maybe i'll wire it constant.
You can run it out through the kick panel and up through the fender, but there a big vacume box in the way up inside that fender, so good luck.
How much power do one of those things pull, I thought you could plug them into the lighter. The only thing I've ever run straight to the battery is an amp for the sound system.
enggass
04-08-2010 06:27 PM
ksutjh
07-11-2007 03:44 PM
XylemXorro
06-02-2007 06:26 PM
matteorr
12-27-2002 04:25 PM
