Using a lot of gas....something's wrong
12-21-2005, 04:23 PM
on
12-21-2005, 04:31 PM
on
Does it miss, do you have a check engine light on, do you have any codes?
12-21-2005, 04:44 PM
on
doesn't miss....check engin light is on.....my speedo is off but i guess their could be other codes in there now
12-21-2005, 05:07 PM
on
Get the codes checked and go from there.
12-21-2005, 05:17 PM
stop at Auto Zone or somewhere that will read the codes for free, and give you and idea of what is wrong. then post the codes and reasons here and guys can say if they have had similar problem or known problem.
12-21-2005, 06:43 PM
on
02 sensor.....it's bank 2 sensor 2.....got the sensor.....is that the one on drivers side behind the cat.....or is it passengers side behind the cat??
12-21-2005, 08:09 PM
on
fixed...what a difference.....back to normal.....filled it up then checked MPG....18.3.....back to normal
12-21-2005, 09:04 PM
on
18????
Quote:
18??? I can't get more than 15-16 from my 5.4....glad you found it.
12-22-2005, 05:37 AM
on
yep....i average about 18.....it's a 4.6...5spd.....and i keep my foot out of the throttle.....if i start to get into it hard then it goes down
lucaslaw
08-09-2009 07:36 PM
wmjoe1953
Oregon Chapter
05-13-2009 01:33 AM
fordbubba8206
Electrical Systems/Wiring
07-09-2005 09:20 PM
cedman
19
03-01-2005 07:10 AM
Kai
25
05-01-2003 04:05 AM
