Replacement lower door skins.
Old 12-20-2005, 10:31 PM
delaney's Avatar
delaney
delaney is offline
Question Replacement lower door skins.
On my 53 F100 I will have to replace parts of the lower door skin. Do the replacement door skins that I see in catalogs have the shape of the door formed in them or are they just flat?
Thanks
Old 12-21-2005, 01:31 AM
sierraben's Avatar
sierraben
sierraben is offline
The ones I see look like they're formed to match the door.
But that's just a pic.
If you're planning on getting a repair panel, I'd call and make sure.
At $45.00, each, I would think that they're formed.
Old 12-21-2005, 05:59 AM
scrape's Avatar
scrape
scrape is offline
the ones sold by the oval chain do fit, in and out r much quicker than trying to make them
cya...gary
Old 12-21-2005, 06:43 AM
jniolon's Avatar
jniolon
jniolon is offline
old and in the way
got mine from mid 50 and yes they are formed... and yes they did fit very well
john
Old 12-21-2005, 06:56 AM
mt54's Avatar
mt54
mt54 is offline
Mine also where formed, both inside and outside panels from midfity.
Mike
Old 12-21-2005, 07:31 AM
learpilot's Avatar
learpilot
learpilot is offline
Got mine from Dennis Carpenter and they were formed, fit was fair
Old 12-21-2005, 08:26 AM
54 gene's Avatar
54 gene
54 gene is offline
Midfifty worked fine for me.
Old 12-22-2005, 09:24 AM
Cowman's Avatar
Cowman
Cowman is offline
The door skins I used also were formed and easy to weld in. I had heard pros and cons to using a butt weld vs a lap weld so I did one of each. On one door I cut the old and new parts to align and did a series of tack welds along the butt joint until the skin was completely welded. Then ground the welds flush. The edges need to be folded around the inner panel skin which was at first intimidating. When I finally got started, a hammer and bucking bar made that part the easiest part. I just started folding the lip a little at a time and kept working my way around the door edge. Made serveral passes to get a tight seal.
On the other door I used the lap joint that came with the repair panel and tucked it under the original skin. The welded the joint in a similar manner. So far the I cannot tell which door was done in which manner but if I was doing it again. I think I would stick with the butt joint method.
Hope this helps.
Old 12-22-2005, 10:54 AM
fatfenders56's Avatar
fatfenders56
fatfenders56 is offline
I only needed one but I made it from 18 ga flat stock, butt welded and folded with a hammer, took about 2 hrs, worked for me, real happy with it
Wheelman55
11-13-2016 07:06 AM
Diesel 724
01-25-2016 06:46 PM
clintonvillian
27
04-27-2015 09:52 PM
leforrest
Paint & Bodywork
04-24-2014 07:55 AM
rich1brad
11-19-2011 02:20 AM
Quick Reply: Replacement lower door skins.
